975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 06:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline Flights
Author Topic: Redline Flights  (Read 872 times)
mightynimrod
Redline Flights
« on: November 05, 2006, 03:58 PM »
Hi ya fellas,
Can anyone tell me what year flights these are please?
I want them to go on my 86 Haro and need to know if theyre era correct and what i should pay including everything BB e.t.c
Steve
Re: Redline Flights
« Reply #1 on: November 05, 2006, 04:01 PM »
look spot on to me single pinch vary price wise from £140/£200 ish give or take.but im no expert.
mightynimrod
Re: Redline Flights
« Reply #2 on: November 05, 2006, 04:02 PM »
Thats what i thought but glad that someone agrees :D
Didn't want to but the wrong ones.
Cheer Dan
Steve
Offline showtime
Re: Redline Flights
« Reply #3 on: November 05, 2006, 04:15 PM »
they are mid 90's non wraparound ones!
are they for an old bike?
for true oldschool you'll want full wrap 401's
look at this pic for easy identification  ;)
mightynimrod
Re: Redline Flights
« Reply #4 on: November 05, 2006, 04:17 PM »
Showtime, what does it mean by "wraparound"???
In the early 80's when i knew of them originally there was only the pinch and non pinch.
Offline showtime
Re: Redline Flights
« Reply #5 on: November 05, 2006, 04:22 PM »
easiest way to describe it is to compare the pedal ends of the top 2 cranks in that pic, the full wraparounds have crank arm all the way round the pedal mounting piece (and the spindle mount with the bolt) & its almost like they have pierced the crank arm (there is crank arm wrapped all the way round them)
then in the 2nd one down you can clearly see the pedal mounting piece is just welded onto the rnd of the crank arm as is the spindle mount, then the pinch bolt is just welded onto the back of that!
its a little hard to desribe but have a close look at the pics & you'll see  ;)
i have a larger version of that image i can mail you if you like?  :)
mightynimrod
Re: Redline Flights
« Reply #6 on: November 05, 2006, 04:25 PM »
That'd be great matey
At least i can compare them now so i dont get ripped off ;)
Cheers dude. :daumenhoch:
Offline showtime
Re: Redline Flights
« Reply #7 on: November 05, 2006, 04:30 PM »
you should have mail  ;)
mightynimrod
Re: Redline Flights
« Reply #8 on: November 05, 2006, 04:35 PM »
Just got it thanks Adam,
Cheers for that.
I understand now what it means by wraparound, it's like the crank arm swallows up the pedal boss and the end of the crank "wraps" around it.
At least i think that's what it is.
Looks that way from wraparound and non-wraparound
Coastvl
Re: Redline Flights
« Reply #9 on: November 06, 2006, 10:12 AM »
Spot on  :daumenhoch: Both ends are actually wrapped around the pedal thread and spindle end. Still nice cranks though.
mightynimrod
Re: Redline Flights
« Reply #10 on: November 06, 2006, 10:36 AM »
You've got to be a picky sod though to spot that ;)
