975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:26 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  90's Hoffman Flash Pro
Author Topic: 90's Hoffman Flash Pro  (Read 2647 times)
Offline generallee
« on: November 04, 2006, 10:28 PM »
Very rare indeed - just stumbled across this NOS hoffman Flash Pro - Its a beauty. Mismatshed superforks, but sod it - still looks nice!!!!!!
Offline Stodgy
    • RADBMX Shop
Re: 90's Hoffman Flash Pro
« Reply #1 on: November 04, 2006, 10:32 PM »
Blimey Steve - you're on a roll tonight. Liking that too...gotta love a flash!
scooby74
« Reply #2 on: January 04, 2007, 01:43 PM »
just bought this frame and superforks from generallee, arrived in the post yesterday and is an absolute gem!!! ;D
This will be my first mid school build and am looking for some info on what parts would be considered appropriate?
I need to have a closer look at the forks, but they seem to be 1 1/8 (will measure later on) with a threaded top with a large black nut  - what kind of headset and stem would need to be used?
Anyone got any info on when the Flash pro was released and what the factory spec was for a complete bike?
any info appreciated folks!
« Reply #3 on: January 04, 2007, 01:53 PM »
use a regular aheadset and stem
the threaded top was for screwing a big nut on to clamp the lot down
some mongooses have the same thing
Offline Stodgy
    • RADBMX Shop
« Reply #4 on: January 04, 2007, 02:11 PM »
I believe that frame is a 1999...original spec (on the complete) as follows:
Hoffman  Flash Pro  1999
BB Shell Width: Unspecified
BB Spindle Length: Unspecified
Bicycle Type: BMX
Bottom Bracket: Unspecified
Brake Levers: Dia-Tech MX-1 rear
Brakeset: Dia-Compe VC-747 rear brakes, Dia-Tech MX-1 rear levers
Chain: KMC 410, 1/2 x 3/32"
Chain Size: 1/2 x 3/32"
Chainrings: 44
Chainstay Length: 14 1/8-15 5/8"
Colors: Anodized White, Chrome-Plated, Orange
Component Group: Not applicable
Crankset: 1-piece chromoly, 44 teeth
Fork Brand & Model: Hoffman Bikes Flash
Fork Crown: unicrown
Fork Material: 4130 chromoly, unicrown crown
Fork Rake: 0.0"
Fork Travel: Not applicable
Frame Angles: 74.0 head, 70.0 seat
Frame Construction: TIG-welded
Frame Tubing Material: 4130 chromoly
Front Brake: Not applicable
Front Brake Lever: Not applicable
Front Derailleur: Not applicable
Front Derailleur Type: Not applicable
Handlebar: Hoffman Bikes Racing Bars
Handlebar Extensions: Not applicable
Handlebar Stem: Hoffman Bikes Super Stem
Head Tube Angle: 74.0
Headset: 1 1/8" threadless Dia-Tech steel
Headset Diameter: 1 1/8" threadless
Hub Front: Mount
Hub Rear: Mount
Hubs: Mount
Largest Rear Cog: Not applicable
Num Rear Cogs: Not applicable
Pedals: Wellgo LU-313U
Rear Brake: Dia-Compe VC-747
Rear Brake Lever: Dia-Tech MX-1
Rear Derailleur: Not applicable
Rear Shock: Not applicable
Rear Shock Travel: Not applicable
Rim Front: Araya 7X
Rim Rear: Araya 7X
Rims: Araya 7X, 36-hole
Saddle: Velo 309
Seat Post Diameter: 25.4mm
Seat Tube Angle: 70.0
Seatpost: HB aluminum, 25.4mm diameter
Shift Levers: Not applicable
Sizes: Unspecified
Smallest Rear Cog: Not applicable
Spoke Brand: steel, 2.0mm straight gauge
Spoke Gauge: 2.0mm
Spoke Holes: 36-hole
Spoke Material: steel
Spoke Nipples: brass nipples
Spoke Type: straight gauge
Sugg Retail: 419.99
Tire Front: Tioga Comp III
Tire Rear: Tioga Comp III
Tire Size Front: 20 x 1.95"
Tire Size Rear: 20 x 1.75"
Tires: Front: 20 x 1.95" Tioga Comp III, Rear: 20 x 1.75" Tioga Comp III
Top Tube Length: 19.75"
Weight: Unspecified
Wheelbase: 35.75-37.25"
« Reply #5 on: January 04, 2007, 03:53 PM »
where the fook did you get that spec from dave?
« Reply #6 on: January 04, 2007, 04:00 PM »
off the top of his head
« Reply #7 on: January 04, 2007, 04:02 PM »
wouldnt be surprised.
scooby74
Offline Stodgy
    • RADBMX Shop
« Reply #9 on: January 04, 2007, 04:29 PM »
thinks its from here http://www.airfreetires.com/specs/Step5.asp?BikeId=708&Brand=Hoffman&Model=Flash+Pro&Year=1999
Taaaaaaa daaaaaaaa
Brilliant site - I've posted the link up before...perfect for mid-school builds!
« Reply #10 on: January 04, 2007, 04:35 PM »
add to favourites.
Offline generallee
« Reply #11 on: January 04, 2007, 06:01 PM »
Enjoy that frame - its  a belter! The forks are indeed 1.1/8" and will fit fine on that frame with a regular unthreaded aheadset - the top nuy just holds it all in place and therefor means there is no need for star nut thing banged into the forks.
cheers!
