976120 Posts in 138973 Topics by 6407 Members - Latest Member: Aristomenis 1974 December 14, 2025, 06:28 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What type of printer for repo stickers
Author Topic: What type of printer for repo stickers  (Read 2857 times)
gjs
« on: September 21, 2005, 07:24 PM »
Does anyone know what type of printer you can use to repo stickers on foil etc :)
Offline ORB
Re: What type of printer for repo stickers
« Reply #1 on: September 21, 2005, 08:48 PM »
a screen printer ;)
12
steve
« Reply #2 on: September 22, 2005, 12:19 AM »
thermal transfer -hot ribbon machines
ie the gerber edge 1 and 2
the roland pc 60 -600
plus any solvent based injet, that uses acetone/amonia - basically screen ink
these machines are generally from 5 feet to 3 metres wide,
-the vutek 3 metre machine is a mere 400,000 pounds and uses 5 metres of material, just to spool up!
-hense you won't get anyone wanting to print a decal set on one
-ask your local sign maker if he has the gerber or roland
-i maybe buying a solvent machine soon
Sanmarcopizza
« Reply #3 on: September 22, 2005, 08:50 AM »
If I am not mistaken you can get adhesive foil inkjet sheets. You will probably find that they will not be very durable as the ink will scrape off, however if you are not gonna ride it, it might be OK for a show bike. I guess you might be able to coat the ink, or put a clear film over the top. And don't forget, you won;t be able to do white.
weston
« Reply #4 on: September 22, 2005, 08:59 PM »
ask at your local pc shop ;D
