Matt,Easiest way is to use one of the old JB adaptors (think alans do them?).It's basically the same helical screw as the drive your flat coaster sprocket sits onto, only it's threaded to take a regular freewheel.Next option is one of the acs freecoaster kits like wolfybmx is selling. Again, you change the helical driver for the acs one and slap on their freewheel.Final option is drilling out the hub and retro-fitting a freewheel hub. Kinda hard to get now, you'll probably end up needing a donor wheel.Hope this helps,Brian.
Are you off loading the coaster hub (or even just the driver and sprocket)?If so, can I have first dib dobs? I could do with the spare parts!!!!!
.......should I keep the coaster ?! they look brand spanking new, never even been set-up ! It'd be a shame to mess with them.......
