975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 07:26 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat and 13/16th seat post
Author Topic: seat and 13/16th seat post  (Read 2106 times)
Offline Waxintaxin
« on: October 05, 2006, 08:41 PM »
do normal seats fit /
or before i hack up a troxel post combo , should i hold fire LOL
Rich :)
Offline Bananaman
  • Le Mans Man
Re: seat and 13/16th seat post
« Reply #1 on: October 05, 2006, 09:32 PM »
Talkin of posts for a Ripper i have an 87 with an Elina UL and a load of shims, anyone sellin a post to fit?????
« Reply #2 on: October 05, 2006, 09:34 PM »
rich they dont fit mate i had two shims on mine and it still moved
Offline Bananaman
  • Le Mans Man
« Reply #3 on: October 05, 2006, 09:42 PM »
So if I get the right post for my Ripper the seat i have already got for it won't fit anyway!!!!!!!!!!#
Bolox :tickedoff:
« Reply #4 on: October 05, 2006, 09:46 PM »
no lol as my areo kashi kept moving with two shims lol
Offline Bananaman
  • Le Mans Man
« Reply #5 on: October 05, 2006, 10:06 PM »
Oh for Fooks sake, thsi has not been my week for this shat!!!!
First my snowflake for me flights has too smaller hole, then me seatpost won't go in me TA, then the new post for me ripper is too big now even when the right post does fit am gonna have a swivle seat :tickedoff:
Anyone wanna buy a shat load of BMX crap :rant:
Offline Waxintaxin
« Reply #6 on: October 05, 2006, 10:31 PM »
so hows it done , cos loads in the museum have normal seats
Rich
duncan
« Reply #7 on: October 05, 2006, 10:37 PM »
Have you tried attaching a seat to the seat-tube end of the post just to test it out ?
Or is there a fixed seattube shim in the way?
Is a Troxel actually smaller diameter than a normal Ripper post? Does it need a shim to fit in a Ripper?
« Last Edit: October 05, 2006, 10:43 PM by duncan »
Offline stuntmaster
« Reply #8 on: October 05, 2006, 10:54 PM »
if you want to run a normal seat then you are going to need shim but if your going to use bike then good luck as it will move when it feel like . i know i did it to my ripper and every now and then  with load s of shims it still moves when it feel like . if you go the troxel post and seat then keep both together if want less grief if using bike and not just a show queen
no1stuntmaster on instagram
« Reply #9 on: October 05, 2006, 11:01 PM »
Lee, you need to get a seat clamp for a smaller post, the type you get on kids bikes (no, NOT a BMX!), I might have one in the shed from my boy's old Trek 16" bike and will have a look at the weekend for you  :daumenhoch:
Offline Bananaman
  • Le Mans Man
« Reply #10 on: October 05, 2006, 11:22 PM »
Top man, but...................................
The ripper has an integral clamp :tickedoff:
Oh fook it, the elina UL will have to stay with the shims and shat!!!
Good point Rich how do all the other bikes go on, Generalee has most late 80's rippers whats his secret!!!???
« Reply #11 on: October 05, 2006, 11:47 PM »
Ah, I see the probem now, not at the seat end but the seatpost clamp end Doh!  There must be a way of tightening it up though as bitd I don't remember getting too many people coming back to the shop with that problem, lots with cracks around the seatpost but no problems with the seatpost moving in the frame  :daumenhoch:
Offline Dingobmxer
« Reply #12 on: October 06, 2006, 07:09 AM »
both my Floval and Ripper xl have the smaller posts and the seats seam to fit fine
 :) DINGO :)
se
« Reply #13 on: October 07, 2006, 02:58 PM »
I've got a 13/16ths Pro neck on my Ripper and to be honest didn't even think about the seat not fitting when I got it. Fitted an Elina Lightning Bolt to it and just tightened the thing until it was snug. It took a bit of work but the seat grips the post fine.
Another top tip I fell across today when trying to make something that could substitute for a Uni seat shim. You know those plastic tubes that bathroom sealant and caulk come in? Get a used on, slice a 1 inch strip off the bottom with a kitchen knie, then cut a tab out. Worked better for me than cutting up a beer can and trying to get it to spiral right.
