975808
Robertflamn
November 26, 2024, 08:42 PM
redline flight help please
Topic: redline flight help please (Read 501 times)
crusty
September 30, 2006, 11:05 AM »
i have flights with sealed bottom bracket the spindle seems a bit loose in the hole is this normal or should it be a tight fit i would imaging the later but would like advise asap as i'm trying to build bike today
thanks to anyone that can help
harris
Founding Fathers
Hoffman's Love Child
Re: redline flight help please
September 30, 2006, 11:07 AM »
yes they should be a shoulder fit nice and tight not over tight thou.if they are loose they will damage the bearing .
Bren Gunn
September 30, 2006, 11:26 AM »
The bearing you are using needs a very fine top hat shim to make the internal size smaller. I think the spindle is 19mm and the bearing 3/4" ... could be the otherway around
zed4130
September 30, 2006, 11:34 AM »
Ask ratty he should no i traded some flights recently not my thing 1pc forever less complicated basically simple like me
steve
September 30, 2006, 02:25 PM »
you might have 20mm bearings
they come in some other brand cranksets
