975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 11:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  sprockets
Author Topic: sprockets  (Read 805 times)
Offline Peanut
sprockets
« on: September 27, 2006, 12:01 PM »
anyone know how to remove a sprocket without a wangdoodly sprocket tool??
Coastvl
Re: sprockets
« Reply #1 on: September 27, 2006, 12:12 PM »
If your not keeping the sprocket, throw it in a vice and squash it in there. Turn the wheel and it'll unscrew if you turn it the right way.
bof
Re: sprockets
« Reply #2 on: September 27, 2006, 01:58 PM »
srip it and put it in the vice.
Offline Moose
Re: sprockets
« Reply #3 on: September 27, 2006, 02:27 PM »
Buy a wangdoodly sprocket tool - it's soooo much easier than messing around with other stuff.
duncan
Re: sprockets
« Reply #4 on: September 27, 2006, 02:37 PM »
I got a Cyclo sprocket remover (chain wrench thing) for £9 from Halfords.
I'd avoided buying one for years 'cos I thought I'd never use one more than once, but it has come in handy a few times since.
Much easier to take a sprocket off and disassemble to clean, rather than poking around with a toothbrush/rag when it's still on the wheel.
I just remembered I used an old bikechain once, and wrapped on old towel round a loop of chain I held onto (otherwise it'll cut into you).
Got the sprocket off eventually but I almost buckled the wheel in the process -  far better to get a tool if you want to save the sprocket, sometimes they're stuck on REALLY tight.
Park Tools do a fancy version if you want to spend a ton of money, but the Halfords one does the job.
« Last Edit: September 27, 2006, 02:46 PM by duncan »
