975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 08:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  odyssey pitbull on my ripper
Author Topic: odyssey pitbull on my ripper  (Read 1539 times)
johnty22
« on: September 24, 2006, 12:29 PM »
can anyone tell me if i am doin something wrong  here , the adjuster touches the back of the seat tube, its too long wont fit a t all.  thanks.
 http://i100.photobucket.com/albums/m40/johnty22/DSC00016.jpg
Offline generallee
Re: odyssey pitbull on my ripper
« Reply #1 on: September 24, 2006, 12:34 PM »
Take the adjuster off! [take off the black part with the arm and cable stop] YOu only need to have the main part of the brake, the bolt that hold it in place and the V shaped cable yoke/hanger - then the outer cable stops on the other side of the seattube, but you need a threaded barrel adjuster to sit in the hole in the seattube. So it goes - brake lever - outer cable - barrel adjuster in seatube - then cable clamps to the V yoke just behind the brake. Yo can get a barrel adjuster anywhere - new school bikes use them for the rear ad990 set up in the same way.
cheers!
steve
johnty22
« Reply #2 on: September 24, 2006, 12:43 PM »
steve cheers pal , topman .
