Have you tried twatting it with a hammer?
It will come off if you let us bum you.
I`ve removed a few similar clamps-not with any finesse (I used a chisel on the spot welds) and just peeled them off.Did no damage other than what wa sleft of the weld had tro be filed/sanded down & then used a regular clamp.A Dremel should do a much tidier job .
I've done a few of these but all I can say is some came off easy and some wont budge for example the ones that worked I was able to Dremel off the spot welds on the back of the clap where the bolt sits and with a bit of force with a screw driver of similar it popped off but a couple of others even after removing the little spot welds they would not budge? so Its a case of try it tentively? just my experience fella someone may know different?
Quote from: Retrodan72 on May 20, 2020, 11:33 AMIt will come off if you let us bum you.What a group bum again? I'm still recovering from the last one
So looks like I need a 31.8mm sized clamp from looking online... that's a big bugger!
Quote from: Swivel on May 20, 2020, 03:51 PMSo looks like I need a 31.8mm sized clamp from looking online... that's a big bugger!Is that in MK1 B*rner territory?
31.8mm is the most common modern BMX racebike size so sure you`ll find something .A few on th bay for about ?6 apiece:)
does it have to be the Berratta style clamp you pictured or can you use a tuff neck style one?
