976202 Posts in 138987 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 21, 2026, 08:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Tuffs questions
Author Topic: Skyway Tuffs questions  (Read 5374 times)
Offline nic968
« on: April 26, 2020, 12:57 PM »
 Hello there...
 I 'm building a rider for one of my sons and I've pulled an old pair of Skyways out of the loft for him to try. They're the old alloy hubbed versions...
 Two questions - What size axle nuts do these take and do I need rim tape? I can't remember - it's been a long time since I used Tuffs...
 Thanks in advance people... :daumenhoch:
Offline Picklez
Re: Skyway Tuffs questions
« Reply #1 on: April 26, 2020, 01:25 PM »
Hi there,
Re rim tape, I've never run tuffs with tape, just inner tube and tyre, and no problems.
Re axle nuts, they're 3/8ths diameter, but in my experience the pitch (or tpi - threads per inch, as they're imperial) seemed to have been randomly selected by Skyway BITD. I've had both common sizes with Skyways over the years, both 24TPI and 26TPI.
But please, this is just my personal experience others on here may have far better knowledge/experience regards this matter.
Unless others can provide better knowledge the only real way to be sure would be either:
1. measure an inch of the axle threaded area and count the number of threads (bit of a ball ache)
2. Buy a Thread Gauge like one of these https://www.ebay.co.uk/itm/2-piece-thread-pitch-gauge-set-metric-and-imperial-SAE-Laser-7691/333504102222?hash=item4da664bf4e:g:Vu8AAOSwzQFeLqXL and measure it.
HTH's  :daumenhoch:
Offline nic968
« Reply #2 on: April 26, 2020, 03:05 PM »
 Many thanks mister...
 I'll try measuring first, but I must also have some of the 'regular' nuts from some Suzue hubs that I can try for size...
 Have a great Sunday.  :daumenhoch:
« Reply #3 on: April 26, 2020, 05:42 PM »
Yep, it was a random lottery on thread pitch bitd. Pretty sure you Suzue ones will be 24tpi, so if they don't fit you need 26tpi  :daumenhoch:
Oh yeah, no tape needed. Tape just covers the back of the spoke nipple and stops it puncturing the tubes :coolsmiley:
« Last Edit: April 26, 2020, 05:44 PM by Spen69 »
Offline nic968
« Reply #4 on: April 27, 2020, 11:21 AM »
 Thanks Spen... ;)
