975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 08:02 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Tyre /tubes high pressure question
Author Topic: Tyre /tubes high pressure question  (Read 5962 times)
Offline fattaffracingco
« on: February 04, 2020, 03:23 AM »
Hi all , ok with the passing of time I ain't 10 stone no more, (in fact I'm a bit of a fat fook )and when riding my midschool lash up with 1.95 on skyways with schwalbe tubes the rear tyre seems quite deflated , tyre is only rated to 35
I'm looking to replace with higher pressure tyres and or tubes , have I got to replace both , and if so any recommendations  ?? Thanks chris
keep it on the blackstuff baby, aww fook it
Re: Tyre /tubes high pressure question
« Reply #1 on: February 06, 2020, 10:05 PM »
You won't be able to put much more than 35psi on skyways bud, the tyre will pop off sadly.
Tubes will be fine, new school tyres are way better and rated around 65 to 100psi but you need rims that are a) tight and b) don't flex  :coolsmiley:
« Reply #2 on: February 07, 2020, 11:23 AM »
Should be ok going past 35 - I used to go up to about 50 when I ran tuffs
Disclaimer: if they do explode it's on you
« Reply #3 on: February 13, 2020, 06:21 AM »
Ha ha , thanks both , I will order new tyres and suck n see , I will just up it ever so slightly , this bike only sees very subtle action , rideouts etc🤙
