975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 07:26 AM
RADBMX.CO.UK  |  Old School BMX 1980 - 1988  |  Old School Race (riders ready, pedals ready... GO!!)  |  new build 1984ish curtis mini
Author Topic: new build 1984ish curtis mini  (Read 8359 times)
Offline steve
« on: June 09, 2019, 08:55 PM »
Curtis mini ,
start with the ebay frame, selling stuff and happened to see it , didn't really want to do one.
£55 delivered , will be using them forks until I have some mini ones made...…….
Offline steve
Re: new build 1984ish curtis mini
« Reply #1 on: June 09, 2019, 08:58 PM »
campy bb
120mm I hope its wide enough!!
£13.99 delivered
total
£68.99
Offline steve
« Reply #2 on: June 09, 2019, 09:02 PM »
campagnolo headset
will be 30.2, the headtube will be 32.6mm - will be wrapping some tape around!!
campy headset
£26.48 delivered
total
£95.47
« Last Edit: June 09, 2019, 09:09 PM by steve »
Offline steve
« Reply #3 on: June 09, 2019, 09:11 PM »
going to be running some 1 3/8ths wheels to use the campy caliper
freebie
total
£95.47
Offline steve
« Reply #4 on: June 09, 2019, 09:14 PM »
bb bearings, I imaging they fit the campy cups?
£2.99 delivered
total
£98.46
Offline steve
« Reply #5 on: June 09, 2019, 09:29 PM »
[ Attachment: You are not allowed to view attachments ] 1985 c-record 36 hole small flange hubs
I am sure they cost me about  £90
plus I just bough [ Attachment: You are not allowed to view attachments ] new bearings
you have to watch out as 1985 c-record bearings change sizes, PLUS they differ in size front to rear!!
on the front you buy a weld tite m9 axle, you run the campag cones up this axle, re-cutting the threads in the cones - its different
weld tite axles front and rear £5.49 x 2 = 10.98
two sets of bearings £3.49 and £3.89
hubs £108.36
total
206.82
« Last Edit: June 09, 2019, 09:39 PM by steve »
Offline steve
« Reply #6 on: June 09, 2019, 09:51 PM »
had some mini bars and a dk stem,
they will get a strip and polish
freebie
total
£206.82
Offline steve
« Reply #7 on: June 09, 2019, 09:56 PM »
have some capy cranks, 172.5mm bit too long for this, will need stripping and polishing, they have a 44 tooth ring on that's too large to.
If any one want to swap for some 165mm arms, I will sling in the ring and a usa sized bottom bracket, its missing one part, but the axle is there!!
cranks
freebie
total
£206.82
Offline steve
« Reply #8 on: June 09, 2019, 10:00 PM »
218mm spokes, now its a bit of a guess, but I am in hope that 218mm is low flange hub and 451mm 20 by 1 3/8ths rims!!
I have a pair of sun cr-18 rims from about 1990, they will be going on
also have some red 1 3/8 tyres, but the rear is worn out
I have one all blck tioga comp 3, need another
spokes 100 at £9.99 delivered
total
£216.81
« Reply #9 on: June 10, 2019, 09:29 AM »
Chrome on frame looks good. :)
Offline chrisv39
« Reply #10 on: June 21, 2019, 08:03 PM »
I might be wrong but that looks like a PR Racing frame not a Curtis. Different drop outs to the Curtis. Very nice frame though.
