975825 Posts in 138946 Topics by 6376 Members - Latest Member: The Carrot Cruncher December 27, 2024, 08:25 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Help fitting an Haro disc to opc
Author Topic: Help fitting an Haro disc to opc  (Read 4531 times)
Offline Keepad
« on: May 07, 2019, 05:06 PM »
Hi,
 Could I have a bit of help please, so I took my Haro sport to the local bike shop for a service and parts fitted, the only issue they had was fitting my Haro uni disc on a Sugino opc, they said I would need a non threaded 24mm internal size washer to sit in between the right hand side bearing locking nut and the disc- I’ve not heard of this before is that correct- pic included showing bb locking nut and gap to disc.
Any help and pee taking welcome or washers
« Last Edit: May 07, 2019, 05:08 PM by Keepad »
Offline Keepad
Re: Help fitting an Haro disc to opc
« Reply #1 on: May 07, 2019, 05:07 PM »
Another pic to be clearer
Offline Ady
« Reply #2 on: May 07, 2019, 06:19 PM »
In the first pic is that the furthest it goes fully tightened ?
The locking nut looks deep enough to clear that gap.
Try it without this spacer they advised, it might mark the disc slightly when tightening, but you normally expect that anyway.
Is it this type of bottom bracket ?
It should really fit..
« Last Edit: May 07, 2019, 06:40 PM by Ady »
Offline Ady
« Reply #3 on: May 07, 2019, 06:29 PM »
Same principle for loose ball or above bearings..
Offline Keepad
« Reply #4 on: May 07, 2019, 06:41 PM »
Hi,
It’s a Tange sealed BB,the nut  clears the Gap but shop said when they fitted it they had Still had a gap, I can only assume once the bearing sat inside the cap and the nut was tightened they had a gap in the between the nut and disc, I might make an cap press and have ago myself.
Offline Keepad
« Reply #5 on: May 07, 2019, 06:49 PM »
This one
Offline Ady
« Reply #6 on: May 07, 2019, 08:01 PM »
It is really easy to fit.
I would tighten the lock nut up to the Haro disc as tight as you can get it then see if any movement in the disc.
Assemble it from there.
The bike shop is probably covering there back to save if any issues.
Offline Keepad
« Reply #7 on: May 08, 2019, 06:43 PM »
Sorted thanks for the help mate,
