975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 01:49 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  HLT. Bars question ?
Author Topic: HLT. Bars question ?  (Read 9522 times)
Offline oldscool
« on: February 18, 2019, 03:06 PM »
Does anyone have any pics or spec on Harry Leary bars. Only reason I ask is I bought a rough Diamond Back pro,I think it is anyway a good few years ago. I have just pulled it out of the barn to do something with. Anyway pulled the grips of and there was a dark brown black residue under the grips , I thought this was grip glue at first that had gone dark over the years but there are remains of it under the crossbar.
If in doubt flat out.
Offline Hurricane1
  • Goin flat out critical in the 80's
Re: HLT. Bars question ?
« Reply #1 on: February 18, 2019, 10:46 PM »
HLT bars have a small drill hole near the end of the left bar end. I believe this was for hanging the bars for the smoke chrome process.
Offline Taipan
« Reply #2 on: February 18, 2019, 10:50 PM »
Lots of bars did that especially if they were anodised or painted as you said...
Offline oldscool
« Reply #3 on: February 21, 2019, 10:59 AM »
Someone must have a pic of some HLT bars or are they normal DB bats with a coating. ?
Offline boltactionuk
« Reply #4 on: March 03, 2020, 07:51 PM »
Not sure if any longer relevant. Do you have the drilled hanging hole as this is a quick easy check along with dims as different sizes produced over the running years. Are they uncut? That's your starting, then obviously smoked residue
Offline oldscool
« Reply #5 on: March 03, 2020, 08:07 PM »
There is smoke residue but they have gas release holes under crossbar.
Offline dannyb
« Reply #6 on: March 03, 2020, 08:50 PM »
Post a picture of the bars, that should help with narrowing down what they might be.  :daumenhoch:
Offline oldscool
« Reply #7 on: March 03, 2020, 10:04 PM »
I’m terrible at getting pics up on here. Photobucket and all that messing. Are you on fb.
Offline Chilli Rinse
« Reply #8 on: March 03, 2020, 10:34 PM »
Try the Tapatalk app, Paul recommended it to me and it makes uploading pics a doddle  :daumenhoch:
« Reply #9 on: March 04, 2020, 10:20 AM »
No need for photobucket
You can upload direct from pc or phone (see guide in welcome section ;) )
Offline dannyb
« Reply #10 on: March 05, 2020, 07:43 PM »
« Reply #11 on: April 02, 2020, 09:32 AM »
Corrrect me  if Im wrong but a Diamond back Pro is not the same frameset as a HLT .
But the Senior pro is similar to the early 1st run of large gusset (of which there are two geometrys of large gussets) but the serial would have to be about 2E onwards  . Different geo and forks on the Pre 82 Pros.
Just a heads up in case   :)  :daumenhoch:
« Last Edit: April 02, 2020, 09:46 AM by hunterdubber »
Offline sparky
« Reply #12 on: April 30, 2020, 09:08 PM »
Corrrect me  if Im wrong but a Diamond back Pro is not the same frameset as a HLT.
Early Pro (that came with dual dropout forks), aka Large Pro there were two variants...the very early ones were based on the MX and were modified in several areas soon after production started by Koizumi in late 1978 and by early 1979 had been replaced by the more common variant.
Senior Pro and HLT exact same frame and forks, both pre and post leverage versions.
Bars were small, medium, medium oversize and large, HLT bars had a custom bend and there were several variations of them too, mainly the width.
Offline Mikku
  • Keeping it RAD in Japan!
« Reply #13 on: April 30, 2020, 10:27 PM »
That's really interesting to know! :daumenhoch:
