975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DX Pedal Axle
Author Topic: DX Pedal Axle  (Read 2943 times)
Offline Chilli Rinse
DX Pedal Axle
« on: February 16, 2019, 05:13 PM »
Can you get new spare axles for Shimano DX pedals from anywhere?
Offline CustardLips
Re: DX Pedal Axle
« Reply #1 on: February 16, 2019, 05:32 PM »
Yes... cheap DX style pedals off ebay usually do the trick.  :daumenhoch:
"WWG1WGA"
Offline Ady
Re: DX Pedal Axle
« Reply #2 on: February 16, 2019, 05:41 PM »
These axles (spindles) fit the DX pedals exactly the same.
You just got to swop over the dust seal on the original DX spindles .
These are 1/2 as the 9/16 go for more money
Cheap set ..
https://www.ebay.co.uk/itm/Old-School-BMX-Shimano-PD-MX15-SX-1-2-Blue-Used/254126022719?hash=item3b2b17603f:g:3jEAAOSwh5ZcZy2v
Re: DX Pedal Axle
« Reply #3 on: February 16, 2019, 06:01 PM »
Thanks guys, I knew you'd put me on the right track. BTW tonight's winning lotto numbers, any ideas?
Offline Ady
Re: DX Pedal Axle
« Reply #4 on: February 16, 2019, 06:28 PM »
Re: DX Pedal Axle
« Reply #5 on: February 23, 2019, 12:59 PM »
I missed out on the pd mx15 pedals in the link provided because I hadn’t actually bought the DX’s at that point. Now I have them there are no cheap Shimano’s for sale. Will the axles from these work? If not I’ll put a request up in the wanted section soon.
« Last Edit: February 23, 2019, 01:09 PM by Chilli Rinse »
Offline CustardLips
Re: DX Pedal Axle
« Reply #6 on: February 23, 2019, 02:08 PM »
What size axles do you need ?
"WWG1WGA"
Re: DX Pedal Axle
« Reply #7 on: February 23, 2019, 02:24 PM »
1/2 would be perfect.
Offline CustardLips
Re: DX Pedal Axle
« Reply #8 on: February 23, 2019, 02:41 PM »
The SR pedals you posted probably won't fit and no need to fork out silly money for other Shimano pedals.  "nono"
These should work fine...
https://rover.ebay.com/rover/0/0/0'mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F392229953064
"WWG1WGA"
Offline Ady
Re: DX Pedal Axle
« Reply #9 on: February 23, 2019, 02:46 PM »
I got a set of DX with 1/2 spindles but need 9/16 .
If you want you could post them off to me and I will swop them out and service them too.
Only thing when you swop out the spindles is the plastic cap DX caps sometimes get damaged when removing.
I have just bought some DX end caps , you can have these £15 to cover 9/16 spindles are worth a bit more than the 1/2.
What colour are you planning on doing ?
Have a look at my thread as I done a set of DX they look like new..
Gold
http://www.radbmx.co.uk/forum/index.php/topic,194319.0.html
Or original polished.
http://www.radbmx.co.uk/forum/index.php/topic,194117.0.html
Re: DX Pedal Axle
« Reply #10 on: February 24, 2019, 03:07 PM »
Thanks for the link. I’ve ordered them today before they sold out! I’ll probably swap out both sides, makes sense.
