975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 07:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wheel building
Author Topic: wheel building  (Read 4549 times)
0 Members and 6 Guests are viewing this topic.
Offline Smidsy
wheel building
« on: February 12, 2019, 07:49 PM »
Looking for wheel builder preferably nr Derby....but willing to travel for the right person.
Got some rims and hubs coming so need someone to recommend suitable spokes and put it all together
Offline Chilli Rinse
Re: wheel building
« Reply #1 on: February 12, 2019, 07:53 PM »
I know Alan's BMX charge £20 per wheel if you supply hubs, rims and spokes.  I think they help you with spoke choice too and will supply if needed.
http://www.alansbmx.com/763/products/custom_wheelbuild.aspx
« Last Edit: February 12, 2019, 08:16 PM by Chilli Rinse »
  • Andy
Re: wheel building
« Reply #2 on: February 12, 2019, 08:23 PM »
That's pretty good. I only live 7 miles away from Alans, but my local bike shop charge £55 to build wheels. They are really good though, and do loads of small jobs for me free of charge, so I can't complain :daumenhoch:
Offline CustardLips
Re: wheel building
« Reply #4 on: February 12, 2019, 09:40 PM »
follow stidds how to an build them yourself
nothing more satisfying  :daumenhoch:
I agree... used it many times and still do.  :daumenhoch:
The pics are gone now though unfortunately.  :(
"WWG1WGA"
Offline Ady
Re: wheel building
« Reply #5 on: February 12, 2019, 09:54 PM »
Honestly give it a go yourself..
Building wheels is the most therapeutic part of the build ( I do personally sad as I am)
Here are some very easy and quick guides to building wheels.
The spoke length guide is so easy to give you the information needed.
The vid of the Aussie bint is very informative is a great help..
If you fook it up a least you tried .. fistblump
This truing tool is great .
https://www.chainreactioncycles.com/tacx-t3175-exact-wheel-truing-stand/rp-prod33904
Here is a great site too work out the spoke lengths.
https://www.prowheelbuilder.com/spokelengthcalculator
Plus a simple detailed guide to building a wheel x3 crossover
Offline Ady
Re: wheel building
« Reply #6 on: February 12, 2019, 09:56 PM »
Ps..
Don’t use your expensive bespoke dining room table as your missus will kill you.. :LolLolLolLol:
Offline Ady
Re: wheel building
« Reply #7 on: February 12, 2019, 10:14 PM »
Offline gary4130
Re: wheel building
« Reply #8 on: February 12, 2019, 10:26 PM »
I agree Ady ,that building wheels is very therapeutic,often do mine while watching tv.
always true my wheels using an old pair of forks and a front brake  :LolLolLolLol:
keep thinking I should get a truing stand,but too tight to but one (that's why I build wheels myself)
Offline Ady
Re: wheel building
« Reply #9 on: February 12, 2019, 10:41 PM »
This was my make shift truing stand like yourself..
But the forks I was using I really shouldn’t have , as these was super rare Haro 89 bashguard forks but did the job.. ::)
« Last Edit: February 12, 2019, 11:10 PM by Ady »
Online Avro
Re: wheel building
« Reply #10 on: February 13, 2019, 08:47 AM »
Building the wheels is easy, it's the truing and tensioning part that does my noggin in. I get there in the end but oh my days.
Wanted: Shimano Aero frame
Wanted: Tange Axeblade frame
Offline Ady
Re: wheel building
« Reply #11 on: February 13, 2019, 10:18 AM »
The trick is to try and get each nipple at equal positions when building hand tight.
I try and count each twist or look at the threads on the spokes as a guide to try and keep the tension the same which makes it easier.
Working from the stem hole twist each nipple half a turn on each going around and around till the tension you feel is ok or flick the spoke for a high pitch equal sounds, but always start where you finished.
It won’t be perfect but doing the above is a great start so you can fine tune on The truing tool..
Zed rims that’s another story..
These are a pain to build as the nipples sometimes wedge into the plastic you must use washers but I have build without with less tension.
« Last Edit: February 13, 2019, 10:23 AM by Ady »
Re: wheel building
« Reply #12 on: February 13, 2019, 07:13 PM »
As most have said, give it a go yourself. It's easier if you copy a wheel first but there are plenty of guides online to help :coolsmiley:
I've built plenty but I can't true wheels for shit though so if you get stuck, Jack at Waller BMX here in the south side of Sheffield will true them for £15 a pair and if you let him know, will do it while you wait but give him plenty of notice and no chance over the weekend, his shop is busy :2funny:
Not too far from Derby if you're stuck but most LBS's will tension a wheel up for you if you build it and can't finish the job, just ask around. Mark (Wini) on here is from Derby so drop him a pm if he knows anyone local :daumenhoch:
« Last Edit: February 13, 2019, 07:16 PM by Spen69 »
Offline oldtired
  • Dirty Old Man
Re: wheel building
« Reply #13 on: February 13, 2019, 09:45 PM »
yup very theraputic , build em yerself  :daumenhoch:
 been using this rig for donkeys years to build my own wheels ,   old akisu forks , now got a magnetic guage to bung on the side n can get    new  rims well under 1/2mm out ,         depending on production flaws,    older/used rims take a little more work but you can get em pretty good ,  as Ady stated the initial tension is the key , the trueing part is easy if you get the tension right to start with , making some spoke tension tools is the place to start  ;) ;) :daumenhoch:
could help out if all else fails
keep thinking I should get a truing stand,but too tight to buy one (that's why I build wheels myself)
as above  :LolLolLolLol:
« Last Edit: February 13, 2019, 10:12 PM by oldtired »
Offline MrD
  • Old enough to know better young enough not 2 care
Re: wheel building
« Reply #14 on: March 13, 2019, 08:56 PM »
To add to this thread
Ive just used this spoke calculator
After 80's Hutch pedal 9/16" spindles Only . Just really need the Right but i'll happily have both :-)
Offline Ady
Re: wheel building
« Reply #15 on: March 13, 2019, 09:39 PM »
See 6 pages down from thread .
I placed the Same link mate 👍
Offline Smidsy
Re: wheel building
« Reply #16 on: March 13, 2019, 09:46 PM »
I ended up getting Danny to build em.
 fistblump :4_17_5:
Offline MrD
Re: wheel building
« Reply #17 on: March 15, 2019, 08:48 PM »
The spoke calculator worked out just fine, one word of caution though, if you're building a radial pattern and having the spoke butt on the outside of the hub (as per pic) then get spokes 1-2mm shorter than the calculator says as the path of the spoke is shorter.
MrD
