Nice to see you doing your take on it. I love the classic Torker look, but as Dan said, this is exactly how we would have done it in the 80s
Looks great Only thing I'm not keen on is the placement of the stem pad/cable routing - if you're gonna run freestyle bars seems counter-intuitive to run the cable like that so you'd never be able to use them?
Quote from: griff on February 04, 2019, 11:17 AMLooks great Only thing I'm not keen on is the placement of the stem pad/cable routing - if you're gonna run freestyle bars seems counter-intuitive to run the cable like that so you'd never be able to use them?True, its placed there as the stem fitted is too big to fit the pad. As soon as my restored pro neck stem is back from the coaters, I will get on the case and rectify it.
Love both of these Steve...i have a pair of green sharp XC grips for sale if any use ?
Both those Torkers look great
Quote from: SDF on February 04, 2019, 01:03 PMQuote from: griff on February 04, 2019, 11:17 AMLooks great Only thing I'm not keen on is the placement of the stem pad/cable routing - if you're gonna run freestyle bars seems counter-intuitive to run the cable like that so you'd never be able to use them?True, its placed there as the stem fitted is too big to fit the pad. As soon as my restored pro neck stem is back from the coaters, I will get on the case and rectify it.New restored Pro Neck finally fitted.
Quote from: griff on February 04, 2019, 04:43 PMQuote from: SDF on February 04, 2019, 01:03 PMQuote from: griff on February 04, 2019, 11:17 AMLooks great Only thing I'm not keen on is the placement of the stem pad/cable routing - if you're gonna run freestyle bars seems counter-intuitive to run the cable like that so you'd never be able to use them?True, its placed there as the stem fitted is too big to fit the pad. As soon as my restored pro neck stem is back from the coaters, I will get on the case and rectify it.New restored Pro Neck finally fitted.
