975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 03:01 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Rob Ridge Brake mod ......
Author Topic: Rob Ridge Brake mod ......  (Read 7909 times)
Offline Suicidepan
« on: December 31, 2018, 10:13 PM »
Does anyone know if there were ever any articles written on how to do the Rob Ridge brake mod ??  "help" :2funny:
Offline chubby
  • Needs Pegs
Re: Rob Ridge Brake mod ......
« Reply #1 on: December 31, 2018, 10:21 PM »
Very early ride mags had it in.......
Sent from my HTC One M9 using Tapatalk
Offline chubby
  • Needs Pegs
« Reply #2 on: December 31, 2018, 10:22 PM »
You on about the mega brake boa stuff ??
Offline Suicidepan
« Reply #3 on: December 31, 2018, 10:26 PM »
I have early RideBMX USA & UK magazines any ideas what year ? USA or UK ?
Offline Suicidepan
« Reply #4 on: December 31, 2018, 10:28 PM »
I want to do the sealed bearing BOA conversion to one of my brakes so I`m looking for info on how to do it.
Offline chubby
  • Needs Pegs
« Reply #5 on: December 31, 2018, 10:30 PM »
Rob used skateboard wheel bearings & turned spacers....
Look up oldschoolace thread about making new ones.....
Ain't as easy as it looks..
Offline john4130
« Reply #6 on: January 04, 2019, 09:32 AM »
it takes 2 bearings in each brake arm, 19mmx10mmx5mm. these are quite cheap and easy to get hold of. i'm sure the axle is from a sealed 10mm rear hub cut to length. you will need small spacers in between the bearings on the brake arms about 3mm wide. the part to hold the spring will probably need to be homemade. i dont know if the brake arms were milled out to suit the bearings but i assume they were, you would need to check the size once you've stripped a brake down. i'll strip down my rob ridge boa and get some pics.
Offline chubby
  • Needs Pegs
« Reply #7 on: January 04, 2019, 09:35 AM »
Arms were milled out
Used 3/8th axle mostly,did a few 8mm ish one's to..
Offline john4130
« Reply #8 on: January 04, 2019, 10:12 AM »
some pics of it stripped.
Offline Suicidepan
« Reply #9 on: January 04, 2019, 01:47 PM »
Great thank you for the pictures! !!!!
Offline retrofreak
« Reply #10 on: January 12, 2019, 02:31 PM »
My favorite side pull brake mod!
