975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 12:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dia Compe Tech levers timeline? need your help!
Author Topic: Dia Compe Tech levers timeline? need your help!  (Read 2032 times)
Offline MrD
  • Old enough to know better young enough not 2 care
« on: December 05, 2018, 07:22 PM »
Hi all,
Been hunting through the interweb for a dateline on Dia compe MX levers (pre bent/tech 2/3/& 4's ) without any luck.
Anyone have any information? failing that do we simply just need to see who's got the earliest & latest in each model to get an idea?
Cheers all
MrD
« Last Edit: December 15, 2018, 01:14 PM by MrD »
After 80's Hutch pedal 9/16" spindles Only . Just really need the Right but i'll happily have both :-)
Offline boofy44
Re: Dia Compe Tech levers timeline?
« Reply #1 on: December 06, 2018, 07:47 PM »
Pre bents are late 70s , tech 2 very early 80s, tech 3 was 83 and tech 4 was 84 I believe.
« Reply #2 on: December 07, 2018, 07:14 PM »
There were three different variants to the Tech 2 levers during 82-85.
Offline MrD
« Reply #3 on: December 07, 2018, 11:11 PM »
Thanks for the replies chaps.
I have seen pics of a
pre bent for 02 83
Tech 2 (x3 designs) - earliest so far is ??81 & 1081 within these 2 dates there was a design change (latest date so far for 2nd design is 0582) But I am sure there are earlier. 3rd design I have dates between 0583 & 1285, As always if you do the research then post it up - so an attempt is attached to hopefully make things clearer ::)
Tech 3 - Earliest so far is 11 82 - latest so far is 04 84
Tech 4 - I've not researched - but happy for dates to add to the list
Anyone got any other dates - earlier or later? I'll attempt to get some sort of idea, happily take PM's to save clogging up the thread. I'll keep updating this thread if you guys tell me the dates you've got in your possesion :daumenhoch:
MrD
« Last Edit: December 15, 2018, 01:13 PM by MrD »
