975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 03:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Sealed tange B.B. fitting
Author Topic: Sealed tange B.B. fitting  (Read 1798 times)
Offline Keepad
« on: November 26, 2018, 04:26 PM »
Hi all, a bit of a stupid school boy  question here, I plan to fit  a sealed Tange bottom bracket for my opc, would any one have a idiot proof guide. I’m changing from a 3pc  so I can’t mirror it when I take the old B.B.  off.
Feel daft for asking.
Offline Keepad
Re: Sealed tange B.B. fitting
« Reply #1 on: November 27, 2018, 06:17 PM »
 No takers then
Offline Ady
« Reply #2 on: November 27, 2018, 07:27 PM »
If it like this type it’s very easy mate...
One nut holds the chainwheel to the opc.
The bearing cups bit of 2x1 wood and a hammer to fit the cups into the frame, doesn’t matter which side as both the same.
Put chainring side Bearing in first feed opc then 2nd bearing.
Then fit x2 nuts for no play then lock together job done.
« Last Edit: November 27, 2018, 07:45 PM by Ady »
Offline Keepad
« Reply #3 on: November 28, 2018, 03:23 PM »
Hi Mate, thanks for the reply, I feel a lot more confident doing this now.
Offline chubby
  • Needs Pegs
« Reply #4 on: November 28, 2018, 04:37 PM »
May find you run out of crank threads for the lock nut. Best buy a normal loose ball BB if that's the case..
