975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 11:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removal of old sticker residue? advice required please
Author Topic: Removal of old sticker residue? advice required please  (Read 2396 times)
Offline Taipan
« on: October 12, 2018, 11:33 AM »
I managed to remove some decals easily but all the sticker residue stayed put! how do I remove this residue without damaging the original paint? so basically what have you lot tried and its worked  :daumenhoch:  please lmk thx  :daumenhoch:
Offline mivvi
Re: Removal of old sticker residue? advice required please
« Reply #1 on: October 12, 2018, 11:48 AM »
I use off the shelf label remover but I expect Acetone would work. I would try this on an inconspicuous area first though, just in case.  :daumenhoch:
Offline thebigdog
« Reply #2 on: October 12, 2018, 11:51 AM »
Normally white spirit is ok.
If not i always use automotive brake cleaner its great stuff to use for that i find
Offline CustardLips
« Reply #3 on: October 12, 2018, 12:21 PM »
WD40.  :daumenhoch:
"WWG1WGA"
Offline Taipan
« Reply #4 on: October 12, 2018, 12:52 PM »
Thx peeps,I tried wd40 no worky  :(  tried white spirits  mixed results? think I have some brake cleaner in the garage,not tried label remover as not looked or seen it?  :daumenhoch:
« Reply #5 on: October 12, 2018, 12:56 PM »
Offline deeman
« Reply #6 on: October 12, 2018, 01:27 PM »
Brake cleaner is effectively thinners, be careful you do not remove / soften the paint underneath. Panel wipe /degreaser for car bodywork does the job  :daumenhoch:
« Reply #7 on: October 12, 2018, 01:43 PM »
I’ve used nail polish remover in the past, that worked ok.
Offline kalex
« Reply #8 on: October 12, 2018, 01:55 PM »
Methylated spirit from home bargains, also use it on cars to remove badge residue.
https://www.google.co.uk/search?ie=UTF-8&client=ms-android-samsung&source=android-browser&q=methylated+spirits
Offline Clean
« Reply #10 on: October 12, 2018, 02:22 PM »
Our Maud's Nail Varnish Remover is outstanding for this.  :daumenhoch:
Cheapest stuff you can find in boots will do the trick.  ;)
