975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 07:54 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing rust - the cheap, non abrasive way
Author Topic: Removing rust - the cheap, non abrasive way  (Read 1215 times)
cd
« on: September 18, 2006, 08:02 PM »
I've used this in the past, forgot about it untill recently, it works, is simple, no chemical worries for those who don't like acids / bases and all you need is some caustic soda and a car battery charger. It is by far the best way to get rid of rust - dissapointed I forgot about it before recently doing some forks in oxalic acid which by the way is hard to come by in the UK.
£1.25 from Focus DIY and you hardy need any. Just pour some in the water - don't worry too much about quantities.
My forks started to bubble straight away.
The solution after 2 hrs with rust removed
What is the method?
A technique for returning surface rust to iron. It uses the effect of an small low voltage electric current and a suitable electrolyte (solution).
What advantages does the method have?
The advantages this method has over the old standbys, like vinegar, Coke, muriatic acid, oxalic acid, wire brushing, sand blasting etc. is that these methods all remove material to remove the rust, including un-rusted surfaces. With many, the metal is left with a "pickled" look or a characteristic colour and texture. The electrolytic method removes nothing: by returning surface rust to metallic iron, rust scale is loosened and can be easily removed. Un-rusted metal is not affected in any way.
What about screws, pivots, etc that are "rusted tight"?
The method will frequently solve these problems, without the need for force, which can break things.
Is it safe?
The solutions used are not hazardous; the voltages and currents are low, so there is no electrical hazard. No noxious fumes are produced. The method is self limiting: it is impossible to overclean an object.
Where did this method come from?
Electrolysis is a standard technique in the artefact restoration business. We all did it at school at some point
What do I need?
A plastic tub; a stainless steel or iron electrode (an old stainless steel spoon is always sitting about the house), water and washing soda / caustic soda and a battery charger. About a tablespoon of soda to a gallon of water. Be sure to add the soda to the water
How long does the solution last?
Forever, though the loosened rust will make it pretty disgusting after a while. Evaporation and electrolysis will deplete the water from the solution. Add water ONLY to bring the level back.
What about the iron electrode?
The iron electrode works best if it surrounds the object to be cleaned, since the cleaning is "line of sight" to a certain extent. The iron electrode will be eaten away with time. Stainless steel has the advantage (some alloys, but not all) that it is not eaten away. I used an old spoon.
How do I connect the battery charger?
THE POLARITY IS CRUCIAL!! The iron or stainless electrode is connected to the positive (red) terminal. The object being cleaned, to the negative(black). Submerge the object, making sure you have good contact, which can be difficult with heavily rusted objects.
How do I know if it is working?
Turn on the power. If your charger has a meter, be sure come current is flowing. Again, good electrical contact may be hard to make-it is essential. Fine bubbles will rise from the object.
How long do I leave it?
The time depends on the size of the object and of the iron electrode, and on the amount of rust. You will have to test the object by trying to wipe off the rust. If it is not completely clean, try again. Typical cleaning time for moderately rusted objects is a few hours. With heavily rusted objects can be left over night.
How do I get the rust off after I remove the object?
Rub the object under running water. A paper towel will help. For heavily rusted objects, a plastic pot scrubber can be used, carefully. Depending on the amount of original rust, you may have to re-treat.
My object is too big to fit. Can I clean part of it?
Yes. You can clean one end and then the other. Lap marks should be minimal if the cleaning was thorough.
After I take it out, then what?
The clean object will acquire surface rust very quickly, so wipe it dry and dry further in a warm oven or with a hair dryer. You may want to apply a light oil or a coat of wax to prevent further rusting.
Will the method remove pitting?
No. It only operates on the rust in immediate contact with unrusted metal. What's gone is gone.
What will it look like when I am done?
The surface of rusted metal is left black. Rusted pits are still pits. Shiny unrusted metal is untouched.
What about nickel / chrome plating, paint, japanning and the like?
Sound plating will not be affected. Plating under which rust has penetrated will usually be lifted. The solution may soften some paints. Test with a drop of solution in an inconspicuous place.
How can I handle objects that are awkward to clean?
There are lots of variants: suspending an electrode inside to clean a cavity in an object; using a sponge soaked in the electrolyte with a backing electrode to clean spots on large objects or things that shouldn't be submerged (like with lots of wood)
How can I dispose of the solution?
Poor it down the drain
Can I use metal containers?
No, use a plastic tub
cd
« Last Edit: September 18, 2006, 10:54 PM by cd »
Re: Removing rust - the cheap, non abrasive way
« Reply #1 on: September 18, 2006, 08:43 PM »
oxalic acid
cd
« Reply #2 on: September 18, 2006, 08:46 PM »
Oxalic acid is difficult to find in the UK and it eats metals aswell as the rust.
silentpartner
« Reply #3 on: September 18, 2006, 10:26 PM »
please sir, can i go to the toilet  :-[
cd
« Reply #4 on: September 18, 2006, 10:33 PM »
I think you can wait till break time
Offline boofy44
« Reply #5 on: September 18, 2006, 10:35 PM »
i bet everyones friend  graeme  has plenty of naval jelly.
