975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 10:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dia compe quick release
Author Topic: Dia compe quick release  (Read 1119 times)
Offline Quadog
« on: March 16, 2018, 09:11 AM »
Hi All,
Would like to have these calipers stripped and polished but unsure how to go about removing the quick release mechanism also once removed can they be re attached
Cheers Scott 👍
Offline Avro
Re: Dia compe quick release
« Reply #1 on: March 16, 2018, 09:26 AM »
You will have to grind of the head of the rivet to release the QR.
There are rebuild kits available from Porkchop or BMXworks (maybe other places too). I guess you could source a rivet elsewhere but the one in the kits is shouldered which make it easier.
The new rivet is formed using what is called a 'rivet snap' (3/8 should do it), simply a punch with a concave end, they are very cheap. It is not difficult at all, you can do it with a hammer like in metal work class. Probably best to use a press for more control.
Wanted: Shimano Aero frame
Wanted: Tange Axeblade frame
Offline mivvi
« Reply #2 on: March 16, 2018, 10:31 AM »
Seen a few posts on this subject and people have done it, seems easier than I thought it would be too. I got blank rivets (alloy though) for tech3 levers off ebay, you may find something on there that's suitable.
Good luck  :daumenhoch:
Offline login_user
« Reply #3 on: March 18, 2018, 12:49 PM »
Why do you need to remove them? can't you strip with nitromoors and then polish? Did that with a pink set, 9yrs ago and they turned out fine.
Offline That Swan Guy
« Reply #4 on: March 18, 2018, 12:51 PM »
Yep it’s paint. No need to take them off
