975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 05:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxalic acid
Author Topic: Oxalic acid  (Read 968 times)
Offline chrisv39
Oxalic acid
« on: December 22, 2017, 04:01 PM »
Going to make a start on my Peugeot build over the festive period and have bought 500g of oxalic acid so I can give the frame a bath. Does anyone know the ratio I need to be mixing this stuff? Frames not too bad just a bit of light pitting and surface rust here and there.
Re: Oxalic acid
« Reply #1 on: December 24, 2017, 01:48 PM »
I don't really use a ratio. Fill the old wheelie bin up with water and mix a 1kg tub of crystals in. Normally 24-48hrs is good enough. If you have a chance rub the yellowing off the frame a few times over the time period.
 :radbmxsmilie:
