975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:42 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Gyro needed
Author Topic: Gyro needed  (Read 6464 times)
Offline McPikie
Gyro needed
« on: December 19, 2017, 01:13 PM »
So after picking up an Eastern Element, it has the front brake going through the headstem but a slingle cable to the rear.
As I fancy a bit of flatland, I'd like a gyro. It has the lugs already on the headtube, so can anyone recommend a decent kit?
Offline Christhejob
« Last Edit: December 19, 2017, 04:30 PM by Christhejob »
Offline McPikie
Re: Gyro needed
« Reply #2 on: December 20, 2017, 09:18 AM »
Vocal sealed one. Lovely
https://www.customriders.com/7553/products/vocal-bmx-shoot-da-b-v2-pro-bearing-gyro-black-blue.aspx
Now, being old school, I've not a clue how that would fit. Does it just sit between the top tube and the headstem?
Actually, on looking, I guess I would need a new stem too as I only have the tabs on the top tube
2017-12-20_09-26-45 by Phil Cookson, on Flickr
2017-12-20_09-26-51 by Phil Cookson, on Flickr
2017-12-20_09-27-00 by Phil Cookson, on Flickr
« Last Edit: December 20, 2017, 09:28 AM by McPikie »
Offline VOIVOD
Re: Gyro needed
« Reply #3 on: December 20, 2017, 05:38 PM »
 :) You`d just need a gyro plate but check to see if your stem is drilled for gyro tabs too.The steerer tube on your forks loooks real short so may not be much room on there for a gyro..  https://www.customriders.com/7461/products/vocal-bmx-flat-gyro-plate-purple.aspx?currency=GBP&gclid=EAIaIQobChMIt6
Offline Christhejob
Re: Gyro needed
« Reply #4 on: December 21, 2017, 03:45 PM »
Dude get a complete vocal budget gyro kit from custom riders they work good. You may need to pee about with spacers under the stem, or get a slightly thinner clamp area stem (the one you have there is a beast)
Offline Christhejob
Re: Gyro needed
« Reply #5 on: December 21, 2017, 03:47 PM »
https://www.customriders.com/7465/products/vocal-bmx-retro-gyro-kit-blue.aspx
Only £13. You don't need the lower bit of it as you have the tabs on the frame.
Whilst you're there order one of these too.
https://www.customriders.com/7560/products/firma-top-load-stem-black.aspx
I reckon if you plumped for a fresh pair of grips too you'd go over £30 and get free post  fistblump
« Last Edit: December 21, 2017, 03:50 PM by Christhejob »
Re: Gyro needed
« Reply #6 on: December 21, 2017, 04:35 PM »
And move those bars forward a bit so they're in line with the forks
Offline McPikie
Re: Gyro needed
« Reply #7 on: December 21, 2017, 04:35 PM »
Cheers dude.
Although I have just been accused of looking at dildos and buttplugs when viewing grips  ;D
Offline McPikie
Re: Gyro needed
« Reply #8 on: December 21, 2017, 04:36 PM »
First thing I did. It was utterly awful
Re: Gyro needed
« Reply #9 on: December 21, 2017, 04:58 PM »
Offline Christhejob
Re: Gyro needed
« Reply #10 on: December 21, 2017, 08:50 PM »
Which is more embarrassing? Porn accessories or BMX shop browsing?
Offline McPikie
Re: Gyro needed
« Reply #11 on: December 22, 2017, 11:16 AM »
In all honesty.... I'm not sure  ;D I've also just remembered, I'm still to pick up my £17 Mongoose win from eBay, which seems to have a gryo on, so going to grab that this weekend and see about swapping any good parts around.
