975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 05:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Coaster brake question
Author Topic: Coaster brake question  (Read 958 times)
jezza
« on: September 15, 2006, 11:38 PM »
Reeeet guys, never had one ov these before, got a set of tuff1s with a coaster gonna put them on me DP, what do it attach the arm to the frame with
does it have to be tight or is it fixed loose.
sorry if this seems lame but ive never done one  :-\
Re: Coaster brake question
« Reply #1 on: September 15, 2006, 11:44 PM »
If the frame has a coaster stay, you can bolt it straight to the frame, I'm guessing you don't so you could use a Dia Compe hinged seat post clamp and pack it out with electrical tape, inner tube or some other suitable packing.  I think that's what Billy did bitd, there was another thread about it very recently but the search tool drives me nuts so I haven't had a look for it  :-\
An alternative would be to make up a bracket using mild steel to loop over the frame chainstay and bolt to the coaster arm.  make sure you use something to protect the frame as it will dig in when you brake hard  :daumenhoch:
Offline billstup
« Reply #2 on: September 15, 2006, 11:46 PM »
If the frames got a coster anchor then bolt it to that, if not then it needs to be clamped to the chainstays. They usually came with a strip of metal that bent around the chainstay, but you can also use a hinged seatpost clamp too, and it does help if it`s nice and tight  :daumenhoch:
« Reply #3 on: September 15, 2006, 11:48 PM »
Always and applies to many things not just your coaster brake  :LolLolLolLol:
jezza
« Reply #4 on: September 16, 2006, 12:09 AM »
im fitting them to this
there is an anchor bracket. so wot nuts and bolts do i need,
« Reply #5 on: September 16, 2006, 12:12 AM »
A 10 or 15mm bolt, washer and nyloc nut should do, the sort of thing you can pick up fom B&Q  :daumenhoch:
Offline Rombloke
  • do one
« Reply #6 on: September 16, 2006, 01:44 PM »
ones that fit in the hole, i think they are normally a 6mm bolt and a nyloc nut
Dave
haro, how do you do
Offline jimwise68
« Reply #7 on: September 16, 2006, 01:48 PM »
good luck with the coaster!  :laugh:
I had one on my TA that I bought early this year. Always wanted one BITD cos I thought it looked cool for rollbacks.
Anyway took my bike out for a ride went to bunnyhop up a kerb levelled my pedals ready for the jump, but had to pedal back to level. You guessed it, stopped almost dead front wheel clipped the kerb and nearly threw me off.
I got home and immediately ordered a freewheel convertor from Alans.
jezza
« Reply #8 on: September 16, 2006, 03:41 PM »
oh the joys  ;D
