975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 11:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Sugino spider on redline loose ball spindle
Author Topic: Sugino spider on redline loose ball spindle  (Read 1532 times)
Offline funkyfresh
« on: October 29, 2017, 08:00 AM »
Having problem with fitting a sugino spider to a Redline loose ball BB spindle. I can space out the spider from the drive arm correctly.
But the hole through the spider is about 5mm larger than in diameter the spindle itself. Am I missing some sort of of tubular space that "pads" out the diameter of the spindle so that the spider is held concentrically on the spindle?
Offline CustardLips
Re: Sugino spider on redline loose ball spindle
« Reply #1 on: October 29, 2017, 08:19 AM »
Sounds like you need a top hat washer mate... something like this...
"WWG1WGA"
Offline funkyfresh
« Reply #2 on: October 29, 2017, 08:37 AM »
Ah, that looks like just the thing. thank you. I will see if I can buy one on its own..
