975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 03:07 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  gyro
Author Topic: gyro  (Read 629 times)
adeshere
gyro
« on: September 14, 2006, 02:01 PM »
We'll i have just bought a NOS upper gyro cable from alansbmx as i can't find a new type that is long enough.
First i noticed that the balls on this cable are larger and then noticed that the thread is smaller.
I had an old gyro cable so thought i'd try and melt the ball off with a blow torch and then see if i could then melt it back on using a mould ,ok dent in a block of wood. I have always wanted to try this ...dont !! it doesnt work.
So, does anyone have a spare old type gyro top plate ?
Re: gyro
« Reply #1 on: September 14, 2006, 02:47 PM »
you should be able to change the screw in adjusters mate
as i did that on me master
have they got a slot cut in em
if so take nut off then swap em over
plus it should have come with spare adjusters
adeshere
Re: gyro
« Reply #2 on: September 14, 2006, 11:47 PM »
The new gyro cables come with the different ends and are slotted.
The original 80's cables are a smaller thread and are not slotted.
I could not get a red long upper cable so i had to geta white 80's gyro cable.
If someone had a spare top bracket off of a old gyro i could use that.  Otherwise, i will have to cut them off
