975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 08:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Potts mod on a Nippon
Author Topic: Potts mod on a Nippon  (Read 2476 times)
Offline ammacopij72
« on: May 26, 2017, 11:45 AM »
Hi fellas, was looking into the Modding a non Potts Nippon and stumbled across this pic. Just wondering if this will this work as it looks like it's done without any change to the caliper?
Sent from my iPad using Tapatalk
Re: Potts mod on a Nippon
« Reply #1 on: May 26, 2017, 01:12 PM »
Yep, that works I have a similar setup on an MX900 but I put a cable ferrule on the QR mechanism (that one might have one too but can't tell from the photo).  I also tried an adjuster on the QR and that seems to work ok too.
« Reply #2 on: May 26, 2017, 01:27 PM »
I wonder if that's an 85 cable
Offline Andyboy77
« Reply #3 on: May 26, 2017, 02:19 PM »
I bet it's an '86 or later - ...unfortunately  :(
Offline Picklez
« Reply #4 on: May 26, 2017, 08:24 PM »
Did nearly exactly that mod to my non-potts nippon. Just I screwed up drilling the QR out in an earlier project when the nippon was going to be anodised  "nono"
As you can see, mine is missing QR. However you can use it, you just remove the original cable clamping nut and bolt and as you're fitting the cable fit the cable adjuster into where the nut-bolt was just removed from.
As for the top adjuster, (sorry if you already know) they're available here (or eBay):
http://porkchopbmx.com/dia-compe-bmx-freestyle-bicycle-brake-adjuster-front/
so, the only mode is, buy the above, and one of these if needed,
http://porkchopbmx.com/bicycle-brake-cable-m6-steel-barrel-adjuster-silver-or-black/
 get an 8mm and a 10mm spanner (if memory serves me correctly) and in about 5-15 minutes yours can look exactly like the one in your photo.
As MartyC said, the adjuster on both ends works, but also allows for more brake adjustment too.
HTH  :daumenhoch:
Offline poorboyee
  • dragos says always wear a helmet
« Reply #5 on: May 26, 2017, 10:00 PM »
 the quick release flexies and wastes braking power anyway, it works far better without it but doesn't look as fancy!! PAUL OSICKA ran his with no top semi D/C-auto adjuster(normal pinch bolt only), because that created flex which robbed brake performance >:D >:D >:D >:D
« Reply #6 on: May 26, 2017, 10:10 PM »
What a fantastic fookin video
Not mad on modern flatland tbh, but love the older stuff  :4_17_5:
Offline chubby
  • Needs Pegs
« Reply #7 on: May 26, 2017, 10:13 PM »
Think I've o e of them widgets somewhere Neil, away for the week but I'll look when I'm back dude .
Offline poorboyee
« Reply #8 on: May 26, 2017, 10:26 PM »
them spinning modern kids would say that was old school being 17yrs old, the vids from 2000 but hes rode the same f/brake set-up since about 94..
Offline ammacopij72
« Reply #9 on: May 29, 2017, 01:56 AM »
Cheers fella, you well?
  • Andy
« Reply #10 on: May 29, 2017, 09:08 AM »
I bet it's an '86, like every other bugger out there  :'(
« Reply #11 on: May 29, 2017, 09:29 AM »
I bet you zoomed in though  :teef:
  • Andy
« Reply #12 on: May 29, 2017, 09:37 AM »
Every time Griff!
Offline Taipan
« Reply #13 on: May 29, 2017, 10:09 AM »
Cool Vid!  :daumenhoch: love the no handed spins!!
Offline chubby
  • Needs Pegs
« Reply #14 on: May 29, 2017, 06:35 PM »
We're all good chum, signal really patchy ere in deepest Dorset 😁😁😁😁
Sent from my HTC One M9 using Tapatalk
