975932 Posts in 138955 Topics by 6390 Members - Latest Member: ggbmx April 24, 2025, 09:16 AM
RADBMX.CO.UK  |  Market Place  |  Trade  |  Dia Compe mx1000 sc front spindle swap for rear - sorted now thanks
Author Topic: Dia Compe mx1000 sc front spindle swap for rear - sorted now thanks  (Read 2312 times)
Offline senick
Hi folks
Got a longer mx 1000 front centring spindle vgc off an 83 brake
Needing a shorter rear the same
« Last Edit: February 23, 2017, 06:13 PM by senick »
Offline bigfatolly
Re: Dia Compe mx1000 sc front spindle swap for rear
« Reply #1 on: February 18, 2017, 01:10 PM »
Would you sell it?
Offline senick
« Reply #2 on: February 18, 2017, 07:36 PM »
Hi
Needing the swap to make a pair really
Offline DY85262
« Reply #3 on: February 21, 2017, 06:48 PM »
Cut it down and use a die to re thread it.  :)
Offline senick
« Reply #4 on: February 22, 2017, 06:16 PM »
Nice idea but the cams for the first spacer are either horizontal or vertical for rear or front
Offline DY85262
« Reply #5 on: February 22, 2017, 06:33 PM »
Agh yes, I remember now. So if you are desperate you could drill the moon shaped washer with two flats to round and rotate 90 degrees. Or you could file two parallel flats on the spindle 90 degrees to the existing. Then again you could just find a rear. Lol good luck.
Offline senick
Re: Dia Compe mx1000 sc front spindle swap for rear - sorted now thanks
« Reply #6 on: February 23, 2017, 06:14 PM »
Sorted now thanks
