975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 07:44 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DK stem problem
Author Topic: DK stem problem  (Read 1104 times)
Offline chrisv39
DK stem problem
« on: February 15, 2017, 09:50 PM »
I've changed my Suntour power stem for a DK and have noticed the DK won't go right down into the steerer tube on the forks.
While it's not a major problem I can feel a tiny bit of flex compared to the Suntour. The wedge on the DK is a lot longer than the Suntour although the shafts are a similar size. I've given the inside of the steerer tube a good clean out but still it seems to hit something as it goes in preventing it from going any further. I'm assuming it's tapered inside looking at the thickness of the outside of the bottom of the steerer tube. Does anyone know of any plain alloy flex fighters available as although it's only about 1/4 inch it's bugging me seeing a bit of the shaft.
Offline rooski
  • Mons Veneris
Re: DK stem problem
« Reply #1 on: February 15, 2017, 10:15 PM »
If you get a longer one , it can be trimmed down in length. :daumenhoch:
Re: DK stem problem
« Reply #2 on: February 15, 2017, 10:49 PM »
Really daft question but it's not hitting the spindle of your front brake is it?
Just check in case..... you never know :-\
Offline chrisv39
Re: DK stem problem
« Reply #3 on: February 15, 2017, 11:05 PM »
No Spen no front brake on. The DK stem has a wedge probably twice the size of the Suntour so I'm guessing the inside of the steer tube is tapered stopping it from going all the way down.
Offline steve69
  • aka. Steve Changa
Re: DK stem problem
« Reply #4 on: February 15, 2017, 11:15 PM »
It is very likely the fork steer tube is internally tapered. I know for a fact some of the Tange forks are like that.
What forks are you using??
Offline chrisv39
Re: DK stem problem
« Reply #5 on: February 16, 2017, 02:38 PM »
Tange made GT forks. When I got the f&f there was a wedge stuck in the bottom of the steer tube.
Offline oldtired
  • Dirty Old Man
Re: DK stem problem
« Reply #6 on: February 16, 2017, 07:06 PM »
you could taper the bottom of the wedge on the dk, if its only about 1/4" as you say then it shouldn't stop the wedge working , shouldn't make any difference to strength,  easy enough to do with basic tools  :daumenhoch:
if the stem sticking up bugs you then i suspect a  flex fighter will do the same  :LolLolLolLol:     they bug the shit out of me
 " i know lets make the stem / fork junction weaker "  :crazy2:  non starter
Offline chrisv39
Re: DK stem problem
« Reply #7 on: February 17, 2017, 09:45 PM »
Short length of alloy tubing ordered to make mini flex fighter. Don't really want to start altering the wedge on the stem incase I ever want to move it on.
