975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 07:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  oddessey Gyro
Author Topic: oddessey Gyro  (Read 994 times)
Offline Quadog
oddessey Gyro
« on: February 03, 2017, 02:49 PM »
Hi all
forgive me if this a stupid question but would a odyssey gyro 2 fit on a 87 master on the catalogue specs it says odyssey gyro was wondering if the 2 is  different
Offline fugazi
Re: oddessey Gyro
« Reply #1 on: February 03, 2017, 03:03 PM »
I think the gyro 2 was the one with oversize barrel adjusters, so the upper & lower plates are different. The gyro unit itself was the same as far as I know.
Edit, forgot to add a 1" gyro 2 would fit but is the wrong era, I think the 2's would be more mid school.
« Last Edit: February 03, 2017, 03:19 PM by fugazi »
Offline Quadog
Re: oddessey Gyro
« Reply #2 on: February 03, 2017, 05:01 PM »
cheers pal
I thought the 2 was a lot newer seen it advertised as mid school but as long as it if fits  that will do me
Offline Andyboy77
Re: oddessey Gyro
« Reply #3 on: February 03, 2017, 05:19 PM »
Gyro 2 came about '92/ '93. Like fugazi said: Gyro2's have bigger barrel adjusters but thicker cables as well! Meaning, if you use something like a DC880 or some caliper of that era (about '87) you will run into troubles making the Gyro-cable fit into the barrel adjuster of the caliper. You would need to run your cable without the endcabs on, to make it fit.
Therefore you should go for a Generation-1 Gyro maybe. The difference is easy to spot: The Gen.1 cup has slots at either sides to make the brake-cables go in.
Gyro2's or later ORYG's ('96+) don't have these slots. I just want to bring this to your attention mate, because many Gen.1-Gyro's get mixed with Gyro2 or Oryg parts to make it looking as a complete. So, you might pay attention to that!  :daumenhoch:
Cheers! Andy
Offline Quadog
Re: oddessey Gyro
« Reply #4 on: February 03, 2017, 07:56 PM »
Thanks for the info you have just saved me a few quid  was just about to buy one off eBay glad I asked now
Cheers Scott
Offline Andyboy77
Re: oddessey Gyro
« Reply #5 on: February 03, 2017, 08:19 PM »
Cheers Scott
I'm glad that helped!  :coolsmiley: If you need more info, just ask!  :daumenhoch:
