975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 18, 2024, 04:09 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  10mm freecoaster hub
Author Topic: 10mm freecoaster hub  (Read 1737 times)
Offline doctor-46
« on: December 09, 2016, 08:35 PM »
I've got a KHE with a taska freecoaster that refuses to work, I've lost count ot the times I've stripped it down and tried different sized spacers in it, and have finally admitted defeat with it!
Where can I find a new hub?
After 6months of searching I can only find 14mm axle versions that cost about 5x what I paid for the whole bike!
I have considered opening up the dropouts or grinding flats on a 14mm, but as a last resort....
'86 GT pro performer
'07 KHE Jesse Puente equilibrium
'12 GT calafia
Offline gary4130
Re: 10mm freecoaster hub
« Reply #1 on: December 10, 2016, 12:03 AM »
Put a wanted add up on here mate,or keep looking on eBay for one as they show up,had a couple from there
Plus I've had a few off rad members,taska ones and suntour  freecoasters (which I prefer)
I too have had an issue with a taska-mine just kept slipping when riding even after stripping-reapaking +changing washers etc
Had a suntour one for 20+ years and still works fine
Offline john4130
« Reply #2 on: December 10, 2016, 09:03 AM »
got a nos ultimate hardware one somewhere, but i dont think i have the cog and spring for it. will have a look later if any good to you.
Offline oldtired
  • Dirty Old Man
« Reply #3 on: December 10, 2016, 09:28 AM »
can get this with 3/8 bolts ,   looks like that is the one listed ,    you can always take the color off if your not keen on it
http://www.chainreactioncycles.com/cult-v2-match-freecoaster-hub-rasta/rp-prod149207?gs=1&gclid=CIr00tOm6dACFcO4GwodM-UEKQ&gclsrc=aw.ds
 there are a few with 3/8 bolts , usually listed as being female axle , just  check the bolt size  :daumenhoch:
« Last Edit: December 10, 2016, 09:58 AM by oldtired »
Offline doctor-46
« Reply #4 on: December 10, 2016, 04:41 PM »
Forgot to mention,  it's a 36 hole hub too.
I did see the exact same hub as mine but in 48 hole on ebay a while back, but was reluctant to pay the £60 he was asking for it incase it was just as bad once I swapped the guts over....
The problem seems to be that the clutch springs have lost their tension.
'12 GT calafia
