I think the top nut is actually longer for these stems? you might have trouble tightening that type shown up when its in place? but I could be wrong? tbh I've only seen the type listed separately that the link shows,maybe one of the fella's on here has a spare in there box of spares
The freestyle ones are higher because the race stem bolts are tightened using an allen key into the center of the bolt - this doesn't work if you're running a potts mod, so the stem bolt is higher to allow you to spanner tighten them.
