975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 01:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Post Aqua Blasting of Skyways
Author Topic: Post Aqua Blasting of Skyways  (Read 918 times)
Offline Retrochrome
« on: September 29, 2016, 02:02 PM »
Just had my Yellow Tuffs Aqua Blasted, Do I now just slap on plenty of WD-40 ?
A bit rougher finish than from factory has anyone used wet and dry on them ?
John.
Offline kalex
Re: Post Aqua Blasting of Skyways
« Reply #1 on: September 29, 2016, 02:17 PM »
There should be a few threads on here about it.
I think alot use wd40 when sanded with wet and dry so I can't seem a problem.
I'm not sure if the wd40 soaks in as it's not to good for aiding braking.
Before you go spraying everything wait till someone chimes in that's actually done it
« Reply #2 on: September 29, 2016, 02:31 PM »
Shouldnt need to wd40 them. People tend to do that when they bleach mags as the thinking is it nourishes the nylon.
It does also provide a protective layer against grease and dirt to a degree so wont harm to do it.
Offline kalex
« Reply #3 on: September 29, 2016, 02:40 PM »
I've never done it but it sounds as if it goes against the grain as your brakes will be useless, or does it eventually soak in
Offline Bobby
  • Going up yonder
« Reply #4 on: September 29, 2016, 02:42 PM »
I had mine done a few months back , they came back dull & the surface was a tad ruff
put them in a bath of water then wet & dry them .....  followed by 2 coats of WD40
Leave them as long as you can for the wd to soak in before fitting & using your brakes
Real men play vinyl
« Reply #5 on: September 29, 2016, 02:43 PM »
Doesnt do your braking any favours initially but id does soak in/dry out. To be fair, at our age, braking is pretty useless on mags anyway  :LolLolLolLol:
Offline Retrochrome
« Reply #6 on: September 29, 2016, 03:12 PM »
Cheers for replies, to be fair it's more about the looks as once resto'd I will prob not ride it anymore....
