975791 Posts in 138942 Topics by 6363 Members - Latest Member: Bmxflex November 11, 2024, 03:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chainring and Freewheel Ratio
Author Topic: Chainring and Freewheel Ratio  (Read 1210 times)
« on: September 06, 2016, 12:17 PM »
I know there have been similar threads about this before.
On a 20" BMX most riders use a 44T Chainring with a 16T Freewheel.
My question; what is equivalent to this on a 24" BMX Cruiser?
I will probably be using a 40T Chainring.  :-\
Thanks in advance.  :daumenhoch:
Re: Chainring and Freewheel Ratio
« Reply #1 on: September 06, 2016, 01:00 PM »
41/17 with 175mm cranks
40/17 with 180mm cranks
« Reply #2 on: September 06, 2016, 03:08 PM »
Cool  :coolsmiley: Is there a chart that I can down load from somewhere? Thanks. :)
Why is it a different set up to a 20"?   :-[
Could you still use a 44T & 16T or would it all be set up wrong. Seen a couple of 24" like this.  :-[
« Last Edit: September 06, 2016, 03:15 PM by BMX1973 »
« Reply #3 on: September 06, 2016, 03:17 PM »
Pretty sure theres a thread on the museum with a link to something, failing that try sheldon browns website
Offline rooski
  • Mons Veneris
« Reply #4 on: September 06, 2016, 07:15 PM »
2.75 is the best ratio for 20" wheels, not sure about 24" bit less I think( 2.3? )
Divide big by small eg 44/16 =2.75  40/15 =2.66
24" wheel is a different ratio as the bigger wheel is harder to turn.
« Reply #5 on: September 06, 2016, 08:57 PM »
Thanks rooski.  :)
Offline Hmoon27
« Reply #6 on: September 06, 2016, 10:04 PM »
There is a table on here somewhere.
44t up front is a bit too big for a cruiser, unless your just pootlin' around. I raced cruiser a few years back , started high up front and ended up riding 39/17👍
Offline VOIVOD
« Reply #7 on: September 07, 2016, 04:38 PM »
« Reply #8 on: September 07, 2016, 09:15 PM »
Thanks chaps.  :)
