975755
TattooedYorkie
September 21, 2024, 11:38 AM
Tuf neck/pro neck big bolt dimensions
Topic: Tuf neck/pro neck big bolt dimensions (Read 1393 times)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
August 30, 2016, 07:47 PM »
Anyone know or can measure the width of the big nut on one of these stems?
Need measurement across the flats and across the widest points of the nut.
Also if someone has one spare let me know
Cheers me dears, Clint
Jaymz
Team RAD
My life is Radbmx
Posts: I am a geek!!
I'm not FOOKING Dave
Re: Tuf neck/pro neck big bolt dimensions
August 30, 2016, 08:04 PM »
25.5mm on my undrilled one that I use to draw the shaft in with.
Jaymz
Team RAD
My life is Radbmx
August 30, 2016, 08:05 PM »
Forget to get point to point. Doh
oldschoolace
Team Moderator
Double Flip Whip
Bodger
August 30, 2016, 08:20 PM »
Guessed it was a little over 22.2 eyeballing it with the bar clamping area
dancetothedrummersbeat
Team Moderator
Tail Whip
Andy
August 30, 2016, 10:09 PM »
I have a spare drilled one
oldschoolace
Team Moderator
Double Flip Whip
Bodger
August 30, 2016, 10:34 PM »
Oooh is it drilled well Andy?
Team Moderator
Tail Whip
Andy
August 31, 2016, 06:29 AM »
Quote from: oldschoolace on August 30, 2016, 10:34 PM
It's decent Clint. Big enough to take a smaller hollow bolt to run a potts mod. I got it from Andy Rooski. He may have some more, but you're wecome to mine. Hopefully you can make some use of it. Pm me your details and i'll get it sent out. I'm away until next week though
