975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 09:58 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Sealed rear hub side to side play?
Author Topic: Sealed rear hub side to side play?  (Read 2121 times)
Offline Hood
« on: June 19, 2016, 03:26 PM »
Hey,
I have just this past week fitted both a front and rear hubguard to my Colony Endeavour. The front hub is solid but I noticed that the rear has a small amount of side to side play?! Now the bike is only just over a month old and I've tbh hardly ridden it, therefore I can't imagine this being down to the bearings etc or at least I hope not?!
I've now gotten the cone spanners required and will be looking at this later. Can anyone please give me an idea on how to tighten a sealed hub, does it involve some sort of lock nut?
Many thanks!
Re: Sealed rear hub side to side play?
« Reply #1 on: June 19, 2016, 08:26 PM »
Thinking about when I fitted one to my rear Cult hub the guard replaced the lock nut, maybe you need to tighten it up a bit
Offline Andyboy77
« Reply #2 on: June 20, 2016, 11:11 AM »
If I understood that correctly, the wheel has side to side play on the axle?
Offline Hood
« Reply #3 on: June 20, 2016, 08:36 PM »
Yes!!
The wheel DID have slight side to side play but I have since stripped it down, removed the drivers side hubguard and found the hub nut on that side was loose!
Have now used my newly acquired cone nut spanners and tightened it! It's now as solid as it should be, all play eliminated!
Many thanks!
« Reply #4 on: June 20, 2016, 08:44 PM »
