975808
Robertflamn
November 26, 2024, 10:01 PM
Mid School ( Keep the faith )
dyno compe 19??
Topic: dyno compe 19?? (Read 5362 times)
sonic-1
dyno compe 19??
September 08, 2006, 02:02 AM »
so any one know anything about dyno bmx s , i just picked one up at a resonable price
its loaded with powerlite goodys crank, front cog , hubs with alex mx22 pro rims , seat clamp
its in great nick must have been given once over by someone who knows a bit about em as its mint
will post a pic when i work out how to do it here
so anyone know anything about dyno then
Last Edit: October 09, 2006, 12:59 AM by sonic-1
huffy
Re: dyno pro comp 19??
September 08, 2006, 01:32 PM »
HEY MR SONIC
IN PHOTO ALBUM CLICK WHICH PICKY YOU WANT,,THEN RIGHT CLICK AND SCHROLL DOWN TO PROPERTIES,CLICK ON THIS AND COPY LOCATION,,AND GO BACK TO YOUR TOPIC AND RIGHT CLICK AND PASTE THIS SHOULD DO THE TRICK
RUSS
Stace
540 Air
September 08, 2006, 03:59 PM »
After uploading a picture in photobucket you will see three different links underneath it. Copy the whole of the text that starts with img.
Paste the whole line of text in your thread and bob's your uncle!!
Last Edit: September 08, 2006, 04:10 PM by stace
sonic-1
September 08, 2006, 04:30 PM »
yippy it works ta much stace
Last Edit: September 08, 2006, 04:32 PM by sonic-1
sonic-1
September 08, 2006, 04:34 PM »
powerlight front cog]
Stace
540 Air
huffy
September 08, 2006, 06:58 PM »
nice
yippeeee
russ
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
September 08, 2006, 07:11 PM »
you need a tool to resize, thry this one.
http://www.irfanview.com/main_download_engl.htm
then all you do is go to file and select the picture
go to image, resize/resample
select the smallest 640x480 and hit ok
then save
sonic-1
September 08, 2006, 08:11 PM »
awwwwww im not real good with puter it was hard enough to get the pic up , not sure about how to mess about n resize em
do yer think its nice enought to put a pic in the museam bit
Stace
540 Air
September 09, 2006, 12:58 AM »
I don't consider the museum to be about 'nice'. Its a snapshot of BMX, whether it a goodun or a feckin stinker, it should go in. This site will be here for years and its all something to refer to and look back on!!
Yours is a goodun, chuck her in!! Who knows, you could be referring your grandkids to a link thats shows them how it supposed to be!! Assuming Photobuckett haven't fecked off
MartyC
Berm Worm
September 09, 2006, 11:43 AM »
Gini does a full set of Dyno f&f stickers for next to nothing too ($15 plus p&p), so could be looking real good and everyone would know what it is
http://home.comcast.net/~rinienterprises/stickpo.htm
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
Reply #11 on:
September 09, 2006, 04:18 PM »
It's just takem me about 2 minutes to do this, rocket science it ain't
Stace
540 Air
Reply #12 on:
September 09, 2006, 05:40 PM »
You built that in two minutes? Feck your fast !
MartyC
Berm Worm
Reply #13 on:
September 09, 2006, 05:44 PM »
I really like the look of the F&F, does anyone know what year it is?
silentpartner
Reply #14 on:
September 09, 2006, 09:11 PM »
thats looking good, but think about changing that seat post. fit some black grips, and loose the plate. IMO
alan
sonic-1
Reply #15 on:
September 09, 2006, 11:26 PM »
mmm was wantin to change the grips , anyone got any good idears what to put on
as for the seat post lookin for a proper lay back one
will b pullin plate off at some point
ta much for the link marty c will get some when i get payed if im allowed
MartyC
Berm Worm
Reply #16 on:
September 10, 2006, 10:24 AM »
I reckon you should try a straight post with the frame angles you should be able to get away with it and still find it a comfortable ride
scottyp
Reply #17 on:
September 10, 2006, 12:21 PM »
its a 97/98 dyno comp. i have one if anyone is interested in one?
Lazarou
Reply #18 on:
September 10, 2006, 07:40 PM »
Looks like an early to mid-nineties Slammer
Lazarou
Reply #19 on:
September 10, 2006, 07:43 PM »
They all looked pretty similar though, but some were tri-moly, not sure about that one, you can ping the frame and if it chimes its cromo!
FIL EBZ
Reply #20 on:
October 03, 2006, 09:45 PM »
I ha d both a compe and detour in the eighties the modles where the drop outs on the front forks where tucked behind the fork tip that bent forward.
Only bike i managed to pull boomerangs on. and the last 1 had had i ground out the rear chain stays and welded in 6mm steel drop outs i ground through the rear stays but never bent an axle LOL
dyno compe 19??
