975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 06:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Araya 7x issue
Author Topic: Araya 7x issue  (Read 2281 times)
Offline Andyboy77
Araya 7x issue
« on: May 02, 2016, 12:12 PM »
Hi everybody,
I have noticed some issues regarding my Araya's. Hopefully I can explain everything properly in my own words. Recently, after I was out for a little ride, I cleaned up the rims. In doing so I felt a very very very ( super very if you will  :) ) subtle wobble of the rim between my fingers. Both rims are showing the same issue.
Yesterday I took the front wheel out to have a closer look at the hub and the axle. I was curious about if I would feel the same wobble by trying to shake the axle. That's tight actually, not the tinyest movement noticable.
What surprised me a little bit though, was the order of cones and lock-nuts. It looks as follows: (pictures - see below  ;) )
At the inside there are the cones and then without a washer there is the lock-nut on either side of the axle. Maybe it has to be like that and in this particular order. That should be the purpose of a lock-nut, to make shure that the inner nut doesn't move, isn't it?
Furthermore I regognised that it's different at the rear wheel. On the right hand side (sprocket) there is a cone and as well without a washer the lock nut, but on the left hand side there is the cone, then two spacers followed by the lock nut.
Even in my limited logic about these technical aspects, I think it isn't meant to be like that. Especially that slightly wobble with the wheels built in, no matter how subtil.
If one solution to this wobble issue would be to tighten the cones a little more, I have to loosen the lock-nuts first, right?
I really appreciate any advice regarding all the above particularised issues  :coolsmiley:
Many thanks in advance and greetings from germany  :daumenhoch:
Andy
PS: I don't know if this of any importance at all, but eveytime I try to ride freehand the bars go crazy and the bike has a tendency to turn left. This could maybe end up in inventing a new trick, but it feels strange.
RIGHT FRONT: order >>> cone / lock-nut
LEFT FRONT: order >>> cone / lock-nut
LEFT REAR: order >>> cone / two washers / lock-nut
RIGHT REAR: order >>> cone / lock-nut (a bit difficult to see, due to the droput being in the way -sorry)
« Last Edit: May 02, 2016, 03:29 PM by Andyboy77 »
Re: Araya 7x issue
« Reply #1 on: May 02, 2016, 02:24 PM »
You shouldn't have any washers between the lock nuts, they should be on the outside of the lock nuts.
Have a look at this page, http://sheldonbrown.com/diy.html or http://www.parktool.com/blog/repair-help
Offline Andyboy77
Re: Araya 7x issue
« Reply #2 on: May 02, 2016, 03:07 PM »
Thanks for your reply. Interestingly there is a picture that shows >>> cone / washer / lock nut  :-\
http://sheldonbrown.com/cone-adjustment.html
...but it is also said: "If the cones are not screwed on far enough, the bearings will have "play": the wheel will be able to shake back and forth on its bearings. This is an unpleasant sensation, and may cause control problems."
That's maybe a part of the solution. ...but thanks   ;)
Offline That Swan Guy
Re: Araya 7x issue
« Reply #3 on: May 02, 2016, 03:14 PM »
If your cones are slightly loose you will not feel it by trying to waggle the axle as you do not have a long enough lever to feel it. But when the wheel is fitted the length of the spoke gives you enough lever to feel it. Taking the wheel off and trying to feel it through the axle will not work. Take the axle out, grease up the bearings and reset the lot. If you can't remember what goes where place the nuts/washers/cones in the order you took them off so that they go back on in the reverse order. As long as it spins ok you can tighten them up but you will not feel any play until the wheel is in the fork and you have got your leverage back.
Offline Andyboy77
Re: Araya 7x issue
« Reply #4 on: May 02, 2016, 03:26 PM »
Thanks Nick  :daumenhoch:  that hepled
I can manage that. Is there any reccomended time interval on serviceing the hubs that should stick to?
« Last Edit: May 02, 2016, 03:30 PM by Andyboy77 »
Re: Araya 7x issue
« Reply #5 on: May 02, 2016, 03:32 PM »
depends if you ride them and whether it's dusty
Offline Andyboy77
Re: Araya 7x issue
« Reply #6 on: May 02, 2016, 06:33 PM »
Yes I will ride them regularly but only on the streets and parking areas. I will not ride bmx tracks.
When I put it all together after serviceing both wheels, what about the two spacers at one side, but none at the other (rear). I might be mistaken, but the rear wheel seems to be of center If I leave it that way.
« Last Edit: May 02, 2016, 06:46 PM by Andyboy77 »
Offline insectbones
Re: Araya 7x issue
« Reply #7 on: May 02, 2016, 07:21 PM »
Put one of the washers on the other side, should even it out  :daumenhoch:
Offline Andyboy77
Re: Araya 7x issue
« Reply #8 on: May 02, 2016, 07:28 PM »
Thanks to you also  :daumenhoch: I will measure it before and afterwards, that should tell it's position.  ;)
Offline Andyboy77
Re: Araya 7x issue
« Reply #9 on: June 09, 2016, 06:04 PM »
Sorted!  :daumenhoch: Thanks for all your replies!
