975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 07:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Why is my bike doing this to my sprockets
Author Topic: Why is my bike doing this to my sprockets  (Read 2015 times)
Offline xmisslucyx
« on: April 21, 2016, 06:29 PM »
Offline xmisslucyx
Re: Why is my bike doing this to my sprockets
« Reply #1 on: April 21, 2016, 06:33 PM »
Its not the teeth is where the spline goes its taking chunks of metal out of it
Sent from my XT1032 using Tapatalk
« Reply #2 on: April 21, 2016, 06:35 PM »
Something isn't tight, or you haven't got a top hat washer on the spindle taking up the gap between the 19mm spindle and 22mm sprocket hole
Offline xmisslucyx
« Reply #3 on: April 21, 2016, 06:37 PM »
I've put 2 different the original and the eastan bike top hat and its still taking chunks out of it
« Reply #4 on: April 21, 2016, 06:39 PM »
Something isn't fitting right, there's play in it somewhere
Offline xmisslucyx
« Reply #5 on: April 21, 2016, 06:39 PM »
I'll take a pic of my spline and set up
Offline xmisslucyx
« Reply #6 on: April 21, 2016, 06:41 PM »
« Reply #7 on: April 21, 2016, 06:50 PM »
That picture is minus the top hat washer right?
Offline xmisslucyx
« Reply #8 on: April 21, 2016, 06:50 PM »
Yes
Offline xmisslucyx
« Reply #9 on: April 21, 2016, 06:51 PM »
Yes
Offline xmisslucyx
« Reply #10 on: April 21, 2016, 07:00 PM »
My friend got the same set up as me and his sprocket is fine
Offline xmisslucyx
« Reply #11 on: April 21, 2016, 07:05 PM »
I was gonna get a new chain new sprocket and back wheel but I don't see the point if my sprocket is getting wrecked
Offline CustardLips
« Reply #12 on: April 21, 2016, 07:24 PM »
Looks messy... might be worth a trip to your LBS.  :daumenhoch:
"WWG1WGA"
Offline xmisslucyx
« Reply #13 on: April 21, 2016, 07:26 PM »
Lbs ?
Offline CustardLips
« Reply #14 on: April 21, 2016, 08:41 PM »
Local bike shop.  :daumenhoch:
"WWG1WGA"
Offline xmisslucyx
« Reply #15 on: April 21, 2016, 08:41 PM »
Its not long come back from there
« Reply #16 on: April 21, 2016, 08:51 PM »
Are the washers to small allowing for small movements? Over time will wear away soft alloys??
Offline xmisslucyx
« Reply #17 on: April 21, 2016, 08:52 PM »
No everything is where it should be
Offline xmisslucyx
« Reply #18 on: April 21, 2016, 09:11 PM »
All the washers top hat pinch bolt spline and crank are new so I Idk why its doing it
« Reply #19 on: April 24, 2016, 09:44 AM »
Have you checked the chain alignment?  It looks like there is some movement in the tophat/chainring which is being exasperated by the chain alignment pulling it to one side.  Does your chain go loose and tight as it rotates?
Offline john4130
« Reply #20 on: April 24, 2016, 10:57 AM »
it looks like the tophat washer is too small, probably a 22mm. try a 23.8mm one or 15/16" one in old money. it should be a tight fit into the chainring.
Offline CustardLips
« Reply #21 on: April 24, 2016, 11:44 AM »
Don't take it back there then.  :LolLolLolLol:
"WWG1WGA"
« Reply #22 on: April 24, 2016, 05:25 PM »
Wise words there  :2funny:
Offline oldtired
  • Dirty Old Man
« Reply #23 on: June 04, 2016, 09:07 AM »
when you put it together is the top hat sat inside the chainring? or on the outside of it?
