975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 05:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Phat Jack hub spoke length
Author Topic: Phat Jack hub spoke length  (Read 1199 times)
« on: March 20, 2016, 10:11 PM »
Anyone ever laced a pair or Phat Jacks?
what spoke size did you use?
Offline kev-s
Re: Phat Jack hub spoke length
« Reply #1 on: March 21, 2016, 03:22 PM »
184mm if my memory is correct, same as normal super pros
You need the correct 12 gauge spokes and nipples which are hard to come by
Think some people have used 14 gauge spokes but they don't look right
« Reply #2 on: March 21, 2016, 03:44 PM »
Cheers Kev  fistblump  ... I might just have to use the standard spokes ... I'll see what I can find
Offline kev-s
« Reply #3 on: March 21, 2016, 04:10 PM »
The 12 gauge spokes can be found but they are not cheap
Last time me and Dannywhac looked you could get them from Australia but they were around £85
If you use 14 gauge spokes be careful as the hub & rim are drilled for 12 gauge so the spoke head and the nipples could cause damage to hub flange & rim
Edit
Found some for under £50
http://www.amazon.com/SPOKES-ACTION-184MM-72PC-SILVER/dp/B001D2WSZ4
http://www.ebikekit.com/spokes-for-350w-grd-20-wheels-184mm/
« Last Edit: March 21, 2016, 04:17 PM by kev-s »
« Reply #4 on: March 21, 2016, 10:39 PM »
Offline kev-s
« Reply #5 on: March 22, 2016, 08:37 AM »
The ones in your link are 14 gauge not 12 :daumenhoch:
« Reply #6 on: March 22, 2016, 03:11 PM »
doh!
 :teef:
