975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 10:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  oryg detangler advice please!
Author Topic: oryg detangler advice please!  (Read 1496 times)
Offline uk-fresh
« on: March 10, 2016, 08:18 PM »
Hi
I need some advice please on the Oryg Detangler. I have purchased the below product for my firebird freestyler. My question is does this only let you connect to 1 brake lever? The instructions that came with it only show it connected to 1 lever. How do I go about having front & rear brakes set up? Apologies if this is a lame question!!!
Offline oldtired
  • Dirty Old Man
Re: oryg detangler advice please!
« Reply #1 on: March 10, 2016, 08:26 PM »
no lame questions on here pal   :daumenhoch: if you don't ask you won't learn , :daumenhoch:
  ( although if you hang around long enough you realise there has been some corkers asked  :LolLolLolLol:
the detangler  you have is for the back brake , the front brake will have to run through a potts mod on your stem  ,  that is a hollow stem bolt that allows you to run the front cable through the forks , have a look at some of the pictures of freestyle bikes with two brakes using a gyro setup  , all will become clear  :daumenhoch:
« Last Edit: March 10, 2016, 08:32 PM by oldtired »
Offline uk-fresh
« Reply #2 on: March 10, 2016, 09:55 PM »
Ok great, just searched ebay and there are some oddesey bolts for sale. By adding a detangler does it limit my choice of headset & stem I can use?
« Reply #3 on: March 10, 2016, 11:39 PM »
no  :daumenhoch:
theres 2 sizes of gyro tho - 1 1/8th for clamp on stems ... 1" for the older bikes
« Reply #4 on: March 11, 2016, 03:21 PM »
If you haven't got a headset yet and it's for an old school ride then buy yourself a Tioga Beartrap II.  They sell for about £30 and are simply the best 1" headset for a rider
Offline uk-fresh
« Reply #5 on: March 11, 2016, 06:47 PM »
what about the below, I have been thinking of getting one of these, a bit pricey admittedly.
TANGE MX-125 headsets, direct from Natsukashi Japan, via Boyds Bikes in London, UK.
« Reply #6 on: March 11, 2016, 09:21 PM »
What frame is going in?
Offline uk-fresh
« Reply #7 on: March 11, 2016, 10:36 PM »
Its going on a firebird freestyler and I was ideally looking for a black headset.
« Reply #8 on: March 11, 2016, 10:39 PM »
I actually wouldn't bother with a gyro as they were a few years before the gyro came out.
Keep it clean and correct, how many bar spins and tail whips do you plan on pulling anyway
Offline uk-fresh
« Reply #9 on: March 11, 2016, 10:49 PM »
to be honest I was in two minds about putting it on. really I should be concentrating on getting the rest of the parts I need so I can start the build, which are headset, stem, seat post, BB & chainring!!!
