975887 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 18, 2025, 09:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Haro Hub Freewheel Threads
Author Topic: Haro Hub Freewheel Threads  (Read 862 times)
Offline Wayne Ryder
« on: February 07, 2016, 03:21 PM »
I've a Haro wheel that's left-hand drive, which is new territory to me and giving me ag. Fortunately the cranks are OK for either side, so that end of things will work out fine (the frame they're going onto has the dimple on the tubing to clear the sprocket).
On the hub, the non-freewheeled side has threads on it. Is this for a regular right-hand-drive freewheel, or is it a flip-flop so that a 13-tooth Odyssey unit can be fitted? I suspect it's the former but without buying a LHD freewheel it's hard to know.
« Last Edit: February 07, 2016, 03:23 PM by Wayne Ryder »
Offline monteryroom
Re: Haro Hub Freewheel Threads
« Reply #1 on: February 07, 2016, 10:27 PM »
Is it like this one I've linked here? Is a straight LHD/RHD hub for full size freewheels.
http://bmxmuseum.com/forsale/111289
Offline Wayne Ryder
« Reply #2 on: February 08, 2016, 10:55 PM »
Apart from the sealed-ness of that one, they look pretty much identical. I reckon that's the case cracked, ta very much.
