975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 08:57 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stem wedge stuck in forks...
Author Topic: Stem wedge stuck in forks...  (Read 792 times)
Offline brass monkey!
« on: January 28, 2016, 11:12 AM »
Anyone got a tip on removing a 'stuck' stem bolt wedge from a a pair of forks?
I'm reluctant to give it too much of a bash - should I soak the wedge and use the stem bolt, scewed in from the underside to ease it out (with a hammer) or is there another safer way. :-[
Ta
Matt
Re: Stem wedge stuck in forks...
« Reply #1 on: January 28, 2016, 11:17 AM »
Is it just the wedge itself stuck?
soaking, threading in an old bolt and knocking from underneath sounds just the ticket  :daumenhoch:
« Reply #2 on: January 28, 2016, 11:25 AM »
indeed, just the wedge - i have removed the stem, and forks from the frame... i'm guessing it needs to come out the way it went in, so planning to soak, and bash from the bottom (ooorrr errr missus !) :crazy2: using the stem bolt sccrewed in the wedge from the underside, unless i can find a long piece of metal which is a similar width to the wedge?
you get me?
Offline insectbones
« Reply #3 on: January 28, 2016, 11:27 AM »
That would be the way I'd do it  :daumenhoch:
« Reply #4 on: January 28, 2016, 12:42 PM »
Update:
It's out  :)
did the necessary, and bingo, the WD40 and big hammer works.
cheers for the replies :daumenhoch:
