975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 04:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ALLY HUB TUFF REBUILD....
Author Topic: ALLY HUB TUFF REBUILD....  (Read 1040 times)
Offline deeman
« on: January 20, 2016, 04:12 PM »
I am rebuilding my front ally hubbed Tuff ....I was wondering how to get the old bearing cups out? I tried a screwdriver and a whack like a bb cup and it did not move but I didn't want to go too mad in case I damaged the hub. Am I tackling it right or is there another way of going about it? any help appreciated...
Damo  :daumenhoch:
Re: ALLY HUB TUFF REBUILD....
« Reply #1 on: January 20, 2016, 04:18 PM »
Pretty sure you just knock them out Damo. Just make sure you have the wheel hub well supported. I dont think its a job that can be done with any reall finesse
Offline deeman
« Reply #2 on: January 20, 2016, 07:19 PM »
Thanks Clint, I will stop touching it up and fooking whack it then!  :daumenhoch:
« Reply #3 on: January 20, 2016, 07:31 PM »
You could carefully take a Dremel cutter to it if you get stuck but it should pop out ( with a big whack!)
make sure you work your way round so it comes out square  :daumenhoch:
Offline 58 delray
« Reply #4 on: January 21, 2016, 09:22 AM »
the raised portion of the outside of the hub needs to be placed on something like suitably sized socket or a vice opened to the correct size so that when you knock the cup out you dont push the hub flange out as well
Offline deeman
« Reply #5 on: January 21, 2016, 11:03 AM »
Thanks Andy  :daumenhoch:
