976221 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 06, 2026, 02:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Does Oxalic Acid go off?
Author Topic: Does Oxalic Acid go off?  (Read 1747 times)
« on: January 16, 2016, 07:01 PM »
As it says in the title. Does Oxalic Acid go off?  :-[ Basically I have a dustbin with it in which is about a year old. It's sunk to the bottom but give it a stir and it mixes again. Is it still any good?  :-\
Thanks in advance.  :daumenhoch:
rodriguez
Re: Does Oxalic Acid go off?
« Reply #1 on: January 16, 2016, 09:02 PM »
I think once you've used it and it's sat for a while it does get a bit weaker but it should still work though might just take longer.
I've stuff I've had for ages I keep in a drum and use to clean the concrete paving in the yard.
« Reply #2 on: January 17, 2016, 05:00 PM »
Maybe I'll add a bit of fresh to it.  ;D
How do you clean your paving then? Just tip it onto it and give it a scrub?  :-\ Sounds like a plan if it works.  :)
rodriguez
« Reply #3 on: January 17, 2016, 07:45 PM »
Yup, just tip it out and give it a scrub, leave for 5 mins and hose off, it's bio-degradable so your not killing the planet   :daumenhoch:
« Reply #4 on: January 17, 2016, 10:05 PM »
Cool.  :coolsmiley:
