975805
V6 DOW
November 23, 2024, 07:44 PM
Suntour sealed bearing hub size
Topic: Suntour sealed bearing hub size (Read 1230 times)
Waxintaxin
Team Owner
Cherry Picker
January 05, 2016, 07:13 PM »
Anyone know the size of the sealed bearings in suntour sealed hubs as I have to replace a set
And I assume an engineer can put them back In etc
Thanks
sawzall
540 Air
Re: Suntour sealed bearing hub size
January 05, 2016, 07:35 PM »
there should be a number on the bearing rich,
try putting the number in a search on ebay you should find them on there
rodriguez
January 06, 2016, 01:33 AM »
I got some a while back and there is indeed a number on the bearing, they are a fairly common size and you need the rubber seal version, the originals were made for Suntour by SKF as far as I remember.
IIRC these are the ones but can confirm if you need.
http://www.wiggle.co.uk/hope-6001-2rs-bearing/
