975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 01:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Primo powerbites
Author Topic: Primo powerbites  (Read 963 times)
Offline gary67
Primo powerbites
« on: January 04, 2016, 12:43 PM »
Picked up a set of these with the pedals still on and the insert is spinning with pedals when you try to remove said pedals. Whats the best way to get them off. I've done one before but it was a messy affair!! :tickedoff: ;D
Offline Gary72
Re: Primo powerbites
« Reply #1 on: January 04, 2016, 01:34 PM »
Is it a single piece steel insert? I would probably go along the route of taking the pedal off with the insert attatched and then clamp the insert in a vice around the edge and try and undo it that way. Also leave it soaking in WD40 or similar for 24 hours.
Offline gary67
« Reply #2 on: January 04, 2016, 03:00 PM »
Had to do that last time it happened to another I'd aquired,had to get a gas torch on it in the end
