975755
TattooedYorkie
September 21, 2024, 07:05 PM
ACS rotor issue
Topic: ACS rotor issue (Read 1058 times)
SAFRANEV6RXE
Curb Endo
ACS rotor issue
January 01, 2016, 08:17 PM »
Got a NOS ACS rotor setup,all mint in bag etc and complete
Now i removed the forks and removed the upper cup in the frame,no probs,then fitted the new ACS cup with the rear brake cable guide connected,then i hit the problem,when i screwed down the large head nut it won,t clear the ACS cup guide and wants to go over the upper cup bearing and it just won,t fit,the rest is fine.
In this link the large nut thats causing issues is in the middle to of the pic at the top.
http://www.ebay.co.uk/itm/Raleigh-Burner-mk2-Headset-/252233200249?hash=item3aba453279:g:~PUAAOSwHPlWcsTy
Last Edit: January 01, 2016, 08:21 PM by SAFRANEV6RXE
SAFRANEV6RXE
Curb Endo
Re: ACS rotor issue
January 01, 2016, 08:29 PM »
Do i need this setup?
http://www.ebay.co.uk/itm/1-Threaded-Bike-Headset-Head-Set-Traditional-Retro-Bike-Cycle-3-Types-/111191367947?var=&hash=item19e385a10b:m:mih39iK_N4NiHjc0Z6EQ5dA
It seems the nut i need sits on top of the cup rather than over it.
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Re: ACS rotor issue
January 01, 2016, 09:24 PM »
Just don't have a rotor, Burners never had them.
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: ACS rotor issue
January 01, 2016, 10:09 PM »
Never did see a burner with a rotor bitd. Sure someone must have fitted one though.
insectbones
Look Back
Re: ACS rotor issue
January 01, 2016, 10:21 PM »
You need to get a picture up, so we can see what you're doing wrong.
Never seen a rotor on a Burner though.
SAFRANEV6RXE
Curb Endo
Re: ACS rotor issue
January 03, 2016, 09:26 AM »
ACS all fitted and works well,bit of a challenge i must admit and its abit primitive but works fine and looks good being NOS,i sorted the nut problem out and set it all up as best i could.
Re: ACS rotor issue
January 03, 2016, 02:08 PM »
Great, now you can do some tailwhips
ACS rotor issue
